| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Well, I got your attention.
Ok, I have been soaking my R33 in CSC for like 12+ hours and the paint is starting to flake (slightly). At the rate it is going it may take a week. The FAQ said it takes 4 hours. What else can be used to strip paint that will not hurt the plastic? The car I am soaking was sprayed w/ Tamiya spray. CSC comes in the big purple jug right? That is what I bought and used. Thx Alfred
AutoArtShop.com Last edited by asaenz; 04-27-2004 at 04:13 AM. |
CSC strips Enamals in 4 hrs, its takes days maybe weeks too strip Laquers like Tamiya. you need a little patience.
You could use Meguiars wax, but I'm not sure about removing the wax once you've gotten rid of the paint.
Re: Castrol Super Clean Sucks
![]() Meguiars wax won't strip paint, it puts a protective layer over it. Alfred, did you get the CSC concrete cleaner or degreaser? They both come in purple jugs but the degreaser is the one you want, the concrete cleaner won't do anything to the paint. Alternatively, when it comes to lacquers, as is mentioned, brake FLUID(not cleaner) is a better bet.
D'oh! I confused that with rubbing compound. Been reading that polishing article too much.
rubbing compound will not strip paint off either. it might rub through a paint job if you rubbed 1 spot way too long.
I have a corvett that i left in csc for a while, the secret is to take it out every night and rubb it down with an old toothbrush, this won't take it off immedieatly but will help the stripping process on tamiya sprays. then i bought a bunch of dot-4 breakfluid and soaked for 1 night and it melted the paint completely off. I had to rub around some of the grooves and edges but is now completely primer and paint free. |
if you need a fast way, i put some thinner on a rag and wipe it ont he car, then get whet dry sand paper, and sand it with the thinner for a couple mine and then wash it off with water. it wont melt the plastic if you work fast and sand good
Re: Re: Castrol Super Clean Sucks
Aaaghh I C. Is that in the FAQ? CSC for enamels, got it. ![]() Ok, I will use break fluid. Thx for all your help everyone al I take back what I said about CSC
AutoArtShop.com |
Oh I meant to ask this.
What about Drayno or similar plumber products? I used Drayno once to remove chrome off plastic wheels. Is that too tough on the plastic, will it work on Tamaya paint? Sorry for all the questions. I just don't want to ruin this Fujimi model. Thx again
AutoArtShop.com |
if i were you i would go to walmart or an autoparts store and get a couple of bottles of dot4 brake fluid. it works fast and won't hurt the plastic.
plus it's like a buck 25 a bottle. |
Use Easy-Off oven cleaner - I guarantee that this stuff will work without harming the plastic at all.
Gunze Color Thinner will strip the paint in no time. But like Junhao says, it will make the plastic brittle, so you have to be careful when handling it. You can use a paintbrush to assist in removing the paint from the plastic surface. The only thing is that Gunze Color Thinner is not cheap.
Thx for all the help guys.
AutoArtShop.com |
