Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 04-26-2004, 06:52 PM
forerunner_fixer forerunner_fixer is offline
Angry 98 four runner with S1000 vip security system from toyota. keyless remote reprogram d
i have a 98 four runner SR5 it has a S1000 vip security system in it from toyota and all the reprogramming i have seent concerns the rs3200. i brought keyless remotes off ebay and i followed the instructions to reprogram them but it doesnt work. help!!!!!
Old 04-26-2004, 08:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 98 four runner with S1000 vip security system from toyota. keyless remote reprogram d
Try this:
1. Insert the key into ignition switch, and turn it to "On"
2. Press and hold the ECU's programming switch for over 2 seconds. Once you see that panel red light turn on for 5 seconds.
NOTE: You must perform the next step within 5 seconds.
3. Press and release the remote control's top or bottom button. Once the exterior (tail and marker) lights flash once then turn off.
4. Turn off the ignition. The system will now operate with the remote control just programmed. It should be able to lock (turn on alarm)/unlock (turn off alarm).
For the ECU, the switch should be a little green pin in a hole, just find something that will push the green pin inside to press it.
Old 04-27-2004, 07:28 AM
this box has the following on it the name of the security system, some patent numbers and 2 sets of plug ins on it. there is no visible holes inthe sides or top of the box. i have even unplugged it and taken it out of the truck but it wont run without it . there is no green hole or button on it .other wise i could have followed the previously posted instructions on here.
Old 04-24-2007, 07:49 PM
marta8191 marta8191 is offline
Re: 97 four runner keyless remote reprogramming
i need instructions for a 97 4runner keyless remote bought at ebay
Old 04-24-2007, 08:47 PM
Brian R.'s Avatar
Resident Chemist
http://programyourremote.com/
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-25-2007, 02:37 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
S1000?
It should be RS3000 for a 98 4Runner, FCC: BAB237131-022. The truck would have been sold with 2 of the GRAY remotes, however you can also use the BLACK remotes.
A vehicle that came with black remotes (96-97) could not use the gray remotes though.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
