Old 04-26-2004, 03:39 PM
Joshta's Avatar
Joshta Joshta is offline
429 Stang Project
Me and two friends of mine have started a mustang project. We have a Ford 429 (not sure what from) and are looking for an older fox body mustang to drop it in. This is a low budget job and really have nothing but the 429, a nice carborater, manifolds, wheels and tires, and an array of junkyard vehicles to rob from. I am looking for a year # with a light weight body(main concern) that can fit the motor, with a decent manual trans. and a stout rearend with acceptable gear ratios. Any year numbers or info is greatly appreciated.
Old 04-27-2004, 12:40 AM
InUrHead InUrHead is offline
Send a message via Yahoo to InUrHead
Re: 429 Stang Project
Your best bet for weight is going to a newer fox. Possibly an 88-93. The motor isn't going to drop in just like that, it's going to involve some body work and probably some metal fabbing of your own. You may be able to find some resources on the net from people who have done it before. I would look around before trying to go with the 429 in a fox, but it does sound intriguing.
The best way to change someone's mind is with a rock.
Old 04-27-2004, 01:04 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
definitely a later fox body, and it should be a notchback. hatchbacks are great for roadracing because of their lower drag coefficient, but notchbacks take drag racing because of their lighter weight. it sounds like a great project, hope it all works out!
that motor might be a cobra jet, did you check the numbers on it?
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 04-27-2004, 01:16 AM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
I had a friend drop a 460 in what think was like and 88 mustang. We called it the beast. It was way ugly but way fast to. He ran nitrous in it to too. Once going down the track it shut off on him so he coasted for almost the entire run and still crossed the finish line at 85mph's. He ran low 10's.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 04-27-2004, 05:38 AM
john67 john67 is offline
I know I 've seen engine mount/oil pan kits advertised to do this swap. I think installing the engine will be relatively easy compared to hooking up a manual tranmission. There might be special bellhousings availlable to put a T-5 behind the 429/460 but it wouldn't have a very long life unless you baby it all the time. That means a step up to the Tremec. I'm pretty sure it has the same bolt pattern as the Ford Top Loader. But you're also looking at a bigger clutch than the 5.0 uses. Not sure if a cable will do the job. It might? Ford used a linkage setup on their old manual trans/clutches and even those had problems with a decent clutch.As much as I like manual trannies, I think for your project, it would be easier to put a automatic behind this engine. You may have to do some clearancing in the tunnel depending on what you use.
Old 04-27-2004, 12:09 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
A 429/460 goes into a Fox-body chassis with not too much hassle. Biggest need is getting a fiberglass hood with enough raise to fit cause a 429/460 is a tall motor hence why it's a fairly easy swap. My choice for what year Fox's would be a 86.
As far as trannies no stock manual tranny is gonna last long behind a big block except a 4-speed toploader. Don't confuse this with the SROD-4 found in 831/2 and early Fox stangs. For ease of install, use and cost I would be looking at a C-6 auto instead of a manual tranny. Also anything older than 86 has a 7.5 rear which won't last long mated to a BB with slicks.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-27-2004, 01:23 PM
z28 boy's Avatar
My friend went with an automatic.
2000 Z28 A4:
Old 04-27-2004, 06:23 PM
Joshta's Avatar
the sticker on the valve cover is sorda scratched. i can see the engine families and a little more, but not much. there is a 4 digit # on the other valve cover. don't know if it's important, any other places to look?
Also, does anyone know what it might have came out of? It's sitting in an old ranger now.
Old 04-27-2004, 06:57 PM
GTStang's Avatar
Stang Guy
It's likely a 429 thunderjet which besides a T-bird was put in a lot of full-size passenger cars back in the day.
Old 04-27-2004, 10:27 PM
Joshta's Avatar
Thanks. assuming it was that, do you know how strong it was?
Old 04-29-2004, 10:16 AM
fajita23200 fajita23200 is offline
Re: Re: 429 Stang Project
Intriguing is an understatement. I'd love to see and hear that project when completed. Anything is possible with enough $$$. I saw a guy drop an LT1 in a Cavalier. It was insanely fast. A 429 properly done would most likely eat him for breakfast.
This above all:To thine own self be true,and it must follow,as the night, the day,thou canst not then be false to any man.(William Shakespeare)
Old 04-29-2004, 07:23 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Get the block casting number off the motor. It should be near the starter area. That would be pretty sweet to get running though.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 04-30-2004, 12:52 AM
GTStang's Avatar
Stang Guy
I know a guy with a worked over 460 in a Fox-stang. They guy who did it knew I was thinking bout doing it to my 83 and convinced em out of it. Bottom line is other than going in a straight line it's not a very good road car. It makes an already nose heavy car heavier and you have now excluded yaself from any NMRA classes except one's that it takes to a $30,000+ car to compete.
Truth be know big blocks really are obselete except in the big heavy cars of yester year
Old 04-30-2004, 03:44 PM
Joshta's Avatar
If we get far along in the project or make a nice milestone, i'll try to post something about it in the future. Thanks for the help.
Old 05-01-2004, 09:44 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
I have seen and heard of LOTs of 429/460 big blocks in fox bodies. They do fit, but as GTStang said, they're tall. You're going to have to either run no hood of a big ol cowl induction hood. A bunch of people make swap kits. Search on google. I searched for "429 fox body swap kit" and this is the first one that came up:
http://www.kaufmannproducts.com/mustangs.htm
Comes with headers, dual sump oil pan, and motor mounts. $900 sounds like a good price - Figure the pan is at least $300 anywhere else, headers at least the same, and much more if you have to get custom headers.
Here is the next site, a bit cheaper at $720:
http://www.mspmall.com/ddautospec/swapkits.html
Its a popular swap for drag racing, you shouldnt have any problem finding info on the swap on the 'net.
