Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 01-13-2002, 12:27 PM
boomtheroom boomtheroom is offline
strap on
what sort of boost could a gts handle if i were to stick a turbo onto it
with the original injectors etc still being used?
Old 01-14-2002, 03:02 AM
anyone?
Old 01-14-2002, 03:16 AM
i would imagine the gts with a turbo and higher octain fuel would kick a gtst because of the higher compression ratio
Dak Dak is offline
A big fat 0PSI unless you did the ECU and injectors, it would run as lean as and melt a piston in no time.
Cheers, Dak.
Old 01-14-2002, 12:14 PM
so if i did the ecu and injectors it would rock?
Old 01-14-2002, 01:16 PM
SlowGts-t SlowGts-t is offline
Send a message via ICQ to SlowGts-t Send a message via AIM to SlowGts-t Send a message via Yahoo to SlowGts-t
and fuel pump, possible AFM, and gearbox, and clutch, and you need an LSD, and you might want bigger brakes hee hee.
I'm a Tokboy
Old 01-14-2002, 03:19 PM
[TWUBLE]'s Avatar
[TWUBLE] [TWUBLE] is offline
boomtheroom... you said it would kick because of higher compression am i right?
I shouldnt think this is the case as higher compression usually makes boost lower am i right?
Proud to be a member of the AF Kiwi Krew!
1 life, 1 licence, 1 day, Save it for the strip...
You cant begin to consider the palpable hate in the air when your near. - s|ipkn0t
Why do I have a conscious. All it does is fuck with me! - k0Rn
Old 01-15-2002, 12:22 PM
maximum boost yes
but boost for boost the gts would have a bigger explosion per stroke
Old 01-15-2002, 02:29 PM
[TWUBLE]'s Avatar
ok but still why not just buy a rb20det and drop that in.... be a hell of a lot cheaper wouldnt it? relatively the same power with more room for improvement right?
PAU-Overhead Assist Strap svi-PAU Park Avenue 0 10-28-2003 08:14 AM
Can i strap on a turbo? NiGhtRider_RS Camaro Discussions 3 08-24-2002 08:43 AM
Recovery/tow straps brad77 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 01-16-2002 05:03 AM
G Shoulder Straps rob99sp General 2 08-30-2001 08:50 PM
