Old 01-12-2002, 10:50 PM
Davidov Speed WRC Davidov Speed WRC is offline
Send a message via AIM to Davidov Speed WRC
Unhappy Oil Burning?
Hi, I'm new to this board so I thought I would ask a question about my 86 Civic Sedan.
Lately my Civic will have this white smoke(smells quite like oil), flume up from around the area of the exhaust manifold.
I wont even have to run my car hard to make this smoke start arising.
One thing I found odd, was that when I checked my oil level(dipstick) it was almost perfectly full. So it must not be burning oil quarts at a time.
My first notion was the head gasket was deteriorating, so I must replace it. I will get to replacing the head gasket within the week.
But before I rip apart the valve cover, any suggestion??
Old 01-14-2002, 03:04 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
That would be my first guess too. It doesn't take a very big leak to make a surpising amount of smoke. You might want to steam clean the front of the engine and see if you can visually locate the leak before you bust open the valve cover.
You should also post this question in the Civic fourm as well, just in case it's a well-known specific problem.
Good luck.
2001 navigator lost oil pressure. dilligaff82 Navigator 0 02-11-2011 06:57 AM
Burning oil at idle bhw33191 Caprice 20 09-13-2009 01:43 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
Proactive Oil Burning Prevention:Head Gasket Oil Drain Issue metalbeast Metro 6 08-02-2008 10:51 AM
Oil burning smell, but oil still golden color & good level just before oil change Shpyder Off-Topic 4 07-25-2004 12:53 PM
