Old 04-22-2004, 09:00 PM
bdzb bdzb is offline
idler pulley broke off
Please help! One of the idler pulleys disintegrated and now my supercharger doesn't work. I tried to replace the pulley, but it's held on by a weird allen bolt and I think I stripped the bolt. I'm thinking of getting a smaller belt and bypassing the idlers by routing it from the crank to the tension pulley, and then the supercharger. Any thoughts or ideas?
Old 04-22-2004, 09:32 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: idler pulley broke off
bolt is called a torque star bit and it is reverse threaded
Dont think your going to be able to bypass it
new pulley will run u 20 bucks from dealer
should be a 5 min fix
Old 04-24-2004, 12:35 AM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
20 from a dealer...that's about what they are from advance or auto zone. I had that problem, my idler pulley locked up and broke, and stripped my tensioner pulley. Had to replace both of them. And I LOVED the looks on the guys at the parts stores' faces when a GIRL (*gasp* *shock*) comes in and knows what car part she needs.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
Old 04-25-2004, 02:23 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
IT is rather easy fix and you would no be able to reroute the belt without the pulley. Would cause more harm than help
Old 04-26-2004, 08:25 PM
BPM BPM is offline
Send a message via AIM to BPM
Ilders run about $10-$15 at O' Reilly's. Easy fix if you have the tork bits. 2 of mine went out within a week of each other
Old 05-11-2004, 09:52 PM
Thanks all, I was able to replace the idler and tension pulleys. The guy at Napa said to use an allen wrench. Last time I ask him for advice.
Old 05-11-2004, 10:06 PM
quikgtp quikgtp is offline
Mine went a couple of weeks ago.My mechanic memoved the pieces and I drove around without the supercharger for a day until the parts came in.It cost me about 200 bucks for both pullies a new belt because it got chewed up and labor.
1997 Black Grand Prix GTP 2 Door
1986 1/2 Porsche 928S
Old 05-11-2004, 10:14 PM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
The SC Idler tensioner are about $120 with the dealer. The OEM part # is 24504818. Mine goes bad too.
This info is from gmpartsdirect.com :
GM PART # 24504818
CATEGORY: Drive Belt Tensioners
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $119.84
OUR PRICE: $68.31
DESCRIPTION: TENSIONER
RED 1999 Grand Am GT - RAM AIR V6 H.O., 4drs, sunroof, and more!
Old 05-12-2004, 07:02 PM
GTPgirl's Avatar
Jeeze, that's freaking expensive for a pulley. No way would I get an OEM pulley if it cost that much. Like I said, I think I gave 20 bucks for mine. And I didn't pay labor, cause me and my dad replaced them.
GTPgirl
Old 05-12-2004, 07:47 PM
Ripn12s's Avatar
He showed the cost of the entire tensioner, not just the pulley.
Pulley alone should be around $20
Old 01-13-2006, 08:38 PM
Huskerstew Huskerstew is offline
Idler Pulley
I just had mine replaced. Cost me $30 from the dealer. Problem was...I didn't know it was reverse threaded....you can see where that's going....broke 2 torx bits...grrr... Anyway...for some reason, the dealer didn't say anything about it being reverse threaded and the one that camin was NOT reverse threaded. Go figure. Anyway....got it out....screwed up some threads and had to put a bolt in to make it work. Problem is now.....I dhave no freaking idea how the belt was routed. Almost seems like I am missing a pulley but I know I'm not. The belt just seems way to big. Anyone have a good diagram for the belt routing???
Old 01-13-2006, 09:30 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Idler Pulley
Timeslip 08/12/06
AF Community Guidelines
Old 01-14-2006, 08:55 AM
Thanks for the pic bnaylor3400. That doesn't look like the engine in my 2000. It looks like the tension pulley immediately to the right of the supercharger isn't even in line with it. Mine is. According to your picture...it is not in the series. Any input???
Old 01-14-2006, 08:58 AM
Duh...just noticed something. I thought this was a bonneville forum and noticed it was for a Grand Prix...sorry.
Old 01-14-2006, 09:25 AM
BNaylor's Avatar
Re: Re: idler pulley broke off
No problem. You had me scratching my head for a while. Hopefully you'll find the info you need in the Bonneville forum. Good luck!
Timeslip 08/12/06
