Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-21-2004, 05:08 PM
tacoma man tacoma man is offline
rochester quadrajet
any one got any suggestions about the quadrajet with
electronic choke. mine needs rebuilt and some told me that
id be better off to just buy a brand new one
Old 04-21-2004, 05:09 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: rochester quadrajet
get a sqaure bore carb. There so much better.
Old 04-21-2004, 05:30 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
if you know how to rebuild it then i would personly go that rought. they are not hard to rebilt you just need to pay atention when you take it apart so you dont lose anything and so you know where everything goes when you put it back together. its pretty straight forward and if you get a rebuild kit from your local parts store then it has a diagram showing all the parts, (not the greatest by anymeans though). as for getting spacificaly a carb that has a square bore, thats kinda up to you. i like spread bore cars, i personly run a quadrajet, cuz they have the small primarys and bigger secondarys so it gives you more or a respoce, not totaly sure how to put it, when you get into the secondaries. lets just say you know when the secondaries open up. now if you dont want to rebild it yourself or have someone do it i would say to just go buy an edelbrock carb. they are a pretty good right out of the box.
Old 04-21-2004, 05:45 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
let me tell ya from experience, if you've never rebuilt a carb, dont make a quadrajet your first attempt
Old 04-21-2004, 07:22 PM
why is everyone so scared of quadrajets. i would prefer to rebuild a quadrajet over a holly anyday. i have done both. the only carb i can think of that i have herd is easier is a edelbrock. i dont know about that cuz i personaly have never rebuilt any edelbrocks.
Old 04-21-2004, 07:31 PM
well i wasnt scared of the quadrajet, but i was
wanting to keep it and my brother said it was
junk and it would probaly cost a lot to rebuild it
Old 04-21-2004, 07:38 PM
oh, i wasnt refering to on when i was talking about people being scared. i was more refering to the coment that 4onFloor said. if you have it profesinaly rebilt then it will probably cost quite abit. probably not as much as a new carb but im not sure. like i said i do my own so i dont know how much someone would charge. but they are by no means junk. i personaly prefer them over any other carb. they are very tunable if you know how to tune them corectly. but your best bet might be to get a new carb. if your going to do that and want a quadrajet still you can get one from jet. i know either summet or jegs sells Jet quadrajets and they have different levels for different performance levels. (Jet is the name of the company incase you didnt know)
Old 04-21-2004, 07:54 PM
I know some Z28's and Trans Am's come
with a quadrajet that was tuned buy a
computer. the model i have come off
an 85 camaro 305 liter. i had the motor
bored out to a 309 and bought new pistons
and had the heads port polished and a valve job.
I wonder what kind of power it will make. thats
why im kind of skeptical about the old quadrajet.
Old 04-21-2004, 08:13 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Every Chevy guy i know thinks Quadra-jets are junk and toss them for another carb as fast as possible.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-21-2004, 09:44 PM
that must be because you dont know any chevy guys that work on carbs. there arnt very many people that like them actualy. yet for some reason they came on many many GM cars from the 60's all the way throught the 80's. there must be something good about them for GM to have used them for so many years. people dont know anything about them so they dont like them. thats the way the world works, if you dont know anything about it you dont like it. its called ignorance. but i personly prefer them and i know how they work and how to make them work.
Old 04-21-2004, 10:40 PM
burnM's Avatar
burnM burnM is offline
I like the Q-jet. It's just a very sensitive carb. My first rebuild was on a Q-jet, and I found it to be fairly easy. Just be sure to adjust the choke spring properly or you'll only run on 2 barrels. Check for warping of the air horn, make sure the throttle plate bushing isn't worn, and make sure to set the float level very carefully.
A problem that most Q-jets are known for is hard starting when cold. This is most likely caused by the main well plugs. They shink over time and let fuel drain when the engine is shut off. Use a quick set epoxy to seal them before re-assembling the carb. Just my 2 cents
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 04-21-2004, 10:49 PM
Twin89s's Avatar
Twin89s Twin89s is offline
Send a message via ICQ to Twin89s Send a message via AIM to Twin89s
Re: Re: rochester quadrajet
very good advice burnM. and its all true. its nice to know im not the only person who doesnt believe all the myths they hear.
Old 04-21-2004, 10:53 PM
so what square bore carb whould you two recomend twin89s and 1992rs? im just curiouse.
Old 04-22-2004, 12:07 AM
DarthD DarthD is offline
I have to agree. The Q-jet has a bad reputation because most people don't know anything about them. I have rebuilt Q-Jets and Holleys and I can honestly say I prefer the Q-jet.
Closed Thread
