I've been looking to build an 11 second fox body mustang. I've explored most options including swapping in a carbed motor and working from there. But I've just decided that I'd keep the stock 5.0 and build on that. I don't want to use NOS nor turbo. I was thinking of going supercharged..I have in mind the vortech s-trim. I'm not sure how far that and bolt ons will get me. so what internals would be beneficial? thanks.
I am running an S-Trim. It will put you into the 11s with no prob. Hyper or forged pistons.
36lbs injectors. 2.95 pulley 12lbs of boost 93 octane Aftermarket ignition 77mm Pro M Tweecer (So you can tune the darn thing) 3.73 or 3.55 70mm TB Good set of alum heads(AFR 185, TFS, Eldebrocks, etc) 9.5:1 Tremec T-Rex Long tube Headers Weld up your torque boxes Some suspension mods, and you are good to go. My 87 is set up that for the most part. When she grips, it goes fast
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Why don't you want to go Turbo?
Re: 11 second mustang?
I prefer the Blower myself just because it provides power right off idle ussually.
Re: Re: 11 second mustang?
Check this out for a comparison.
http://www.dynopro.com/images/graphs...g_Zerban90.gif Specs on this motor: 408 cubic inches, a vortech J-Trim CENTRIFUGAL blower, 16 pounds of boost. http://us.f1.yahoofs.com/users/2dc488c4/bc/Yahoo!+Photo+Album/19+psi+50+50+race+pump+gas+mix.jpg?phKfbhABI1BfRk4 J Specs on this motor: 357 cubic inches, a Turbonetics T76 Q-trim Turbo, 19 pounds of boost. Turbo car outpowers centrifugal car by a sold 200 RWTQ, has a much flatter and more broad powerband, and even outpowers the blower car down low, even though it has a 51 inch displacement disadvantage. |
Re: Re: Re: 11 second mustang?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
well, i'm kind of intimidated of a turbo because i hear they're a alot of work to keep up. but uh..how do turbo mustangs sound? do they sound like your average turbo import? or do they still sound like a american muscle?
ok, i do not own 1, but i have fallen in love with the kenne bell twin-screw blower. it might be a good idea for some of you gues to check out the site...
www.kennebell.net because there is a LOT of info there. in short, the KB for a 4.6 can fun 6lbs of boost w/o an intercooler. supposidly it can run 351rwhp, but im sure those #s come with a lot of tuning. if you want higher HP, than you can go with 9-13 lbs, but those pulley's need the assistance of an intercooler, which KB offers. check out the #s on the site, im sure they are "upped" a little, but doesnt every other site do the same? the main boast of KB is that max psi is obtained by 2000rpm, which means that even if you're runnin down low, you just have to step on it to feel the power, not downshift. if any1 wants to complain about something here, ok. |
You can instal a complete S-Trim in a weekend with just hand tools. The cost is about the same once eveything is said and done.
If your looking at just 11s, I would lean towards the S-Trim.
well thats one thing that scares me..if i go S-trim and get into the 11s i'm going to want 10s. and blowers aren't really that great to upgrade. you kind got what you got. but then with a turbo...i'd always be cranking up the boost because '..i just need to go a little faster' and end up blowing my engine. this might sound stupid but also when i think of a mustang i don't exactly think of turbochargers..and i don't know if i'd like hearing a blow off valve everytime i shift gears..that's more like an import thing. and okay...i assume boosted has a turbo mustang...and skylineusa has an s-trim mustang. which of you guys is in the 11s?
I run turbos on my GTRs.
My Stang has ran a 11.89, but that was also with untuned. Since I have moved to England I have not found anyone to tune to it a fair price. I love turbos, and to say that its an import thing is flat ass wrong. You do not hear the blow off valve every time you shift either.
oh yeah and dirtbike1128...why're you telling me about a blower that will get a 4.6 350hp? first of all, fox body mustang..meaning a 5.0. second 350hp isn't going to get me into 11s unless i gut all the interior and master shifting.
