Old 04-18-2004, 10:31 PM
95 Snake 95 Snake is offline
Stroker Kit?
The 95 is now running on a slim 145 k miles and its time for a rebuild. Ive got about 4,000 at the moment to spend, i think i can find a 347 kit for around 1K. What is the best way to go about doing this, to buy a new block or use the original. thanks
Old 04-18-2004, 10:34 PM
Re: Stroker Kit?
oh yeah and say i went with a 351 block, would my ported cobra intake and gt40 heads support it?
Old 04-18-2004, 11:29 PM
eillob's Avatar
eillob eillob is offline
Ive been looking into strokers myself but the more people and shops I talked to lots of them say to stay away from the 347 if it is a daily driver. They say they don't last very long. Most say to go with a 331 but heres a place Im thinking about buying from. http://www.fordcobraengines.com/stroker.html
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 04-19-2004, 02:47 PM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
Re: Stroker Kit?
I wouldn't go with the 351w. Isn't the 351w block about fifty pounds heavier than the 5.0's. Your gt40 heads won't support the 351, but you could machine bigger 1/2 bolt holes on them to get them to fit if you really wanted to. Stick with a 331 5.0.
Old 04-19-2004, 06:27 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Biggest knock against 347 is oil control which shortens life. But with a good stroker kit and correct pistons for the application then this is not a problem. 331 are good the best choose for a high psi 302 but isn't going to match a 347 N/A each one serves there purpose and serves it well.
Stroked 351 i.e. 393/408 etc.., are a great way to go but just like anytim eyou go bigger the price is more. Your GT-40 can easily be made to bolt on but will be choking a stroked 351 to death. Your Cobra intake will not fit on a 351W set-up
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
