Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-15-2004, 10:59 PM
armpit94sl2 armpit94sl2 is offline
Question Need Help - '94 SL2 Won't Turn Over When Hot
I recently bought a '94 SL2. When the engine is hot, it doesnt turn over. A friend told me it might be the ignition module. Has anybody had this problem before or might suggest how I can troubleshoot it?
What's the difference between the ignition module and the coils?
Old 04-16-2004, 08:07 PM
SC-Xtc SC-Xtc is offline
Re: Need Help - '94 SL2 Won't Turn Over When Hot
Well the coilpacks are mounted on the ignition module.
They do get heated up , being mounted on the tranny.
I remote mounted mine on, a peice of flat stock aluminum, and grounded it.
It works fine haven't had the problem since.
You may need to replace yours, sounds like they are already damaged.
Old 04-17-2004, 02:18 AM
Re: Re: Need Help - '94 SL2 Won't Turn Over When Hot
Thanks for your insight. Would you happen to know where I could find a reasonably priced ignition module?
Old 04-19-2004, 05:50 AM
Mork Mork is offline
When you mean won't turn over do you mean the starter will not turn the engine to start or the engine "Turns over" but will not start?
If the engine will not turn over when hot, you have one of two problems. A) starting motor is dragging and needs replaceing or rebuild. B) Starter has bad ground or corroded wire connections.
Old 04-21-2004, 10:41 PM
Also another posibility.
Try ebay or a local salvage yard, for the module.
If not then I may be able to get you one from a salvage yard here.Let me know at [email protected]
won't turn over when cold rld863 Problem Diagnosis 1 01-11-2010 05:49 PM
Engine won't turn over when it's wet outside Kilgore Trout Eighty Eight 1 02-10-2005 06:11 PM
New Member needs help-'94 B2300 Won't Start regerton B-Series/Bravo/Bounty/Drifter 4 02-01-2005 11:40 AM
HELP '89 Toyota Pick-up Won't Turn Over when Hot JFD Pick-Up 4 06-17-2004 04:48 PM
