Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-15-2004, 10:30 PM
crazyRSX crazyRSX is offline
rsx making noise...do u have a clue what it is?
my rsx occasionally makes a noise...high pitch kinda sounds maybe from a vibration...funny thing is that it happens some times when: 1)i'm driving on the freeway around 70 mph. 2)its really hot weather. 3) when i am not drafting behind another car. (it happens sometimes not all the time but when it does these three things are usually there)
this all leads me to believe it has some thing to do with the arrow-dinamics. its not the breaks cuz it never makes noise when i break. can anyone give me ideas on what it might be...for some reason acura cant find a thing wrong with it. and the noise seems to come and go...wierd
thanks to anyone that can help...and yes my 3rd gear does stick!
crazyRSX aka double clutcher!
Old 04-22-2004, 05:53 PM
crazy_canuck crazy_canuck is offline
Re: rsx making noise...do u have a clue what it is?
Its not the aerodynamics its probably something loose or leaking. Where exactly is the sound coming from?
Old 04-27-2004, 04:56 PM
Re: Re: rsx making noise...do u have a clue what it is?
the sound is coming from the front. it could be around the engine or around one of the wheel wells i'm not to certain.
what is the best way to find out what it is. thank you for the reply.
Old 04-28-2004, 04:03 PM
My guess is something is loose/broken. I doubt its a leak. hard to say where to start, but maybe check if the mudguards/fender lining is snug to the car, and when the car is cold try seeing if anything looks loose. Sorry, thats about the best I can help.
Old 04-28-2004, 04:07 PM
Try posting here: http://forums.clubrsx.com/forumdispl...sprune=45&f=55
I searched but all I found were vibrations from hoods that needed to be adjusted a bit and people who had aftermarket motor mounts and or torque dampers.
BTW, is your car stock?
Old 04-28-2004, 08:32 PM
my car is stock....type-s,i haven't modified anything and i take care of it pretty well. why would it only make noise when its hot weather? when its night time or cool weather it never makes the sound....also the sound is hi pitch almost like feedback on a speaker.
it might be the hood, can you tell me what to look for if it is. this is a tough one. do you think it may be something serious. thanks for checking in on it. let me know if you find anything else.
Old 04-29-2004, 04:04 PM
Well, if it was the hood, it'd jiggle more than usual if you shook it. From the looks of it, I doubt its the hood though.
I don't know why it'd only happen in the heat....that's a tough one.....I can't really figure it out.
Old 05-01-2004, 09:34 PM
RSX-S777's Avatar
RSX-S777 RSX-S777 is offline
Did the dealer check wheel bearings and all that good stuff?
I've got a fever. And the only prescription is more cowbell...
Old 05-03-2004, 12:53 PM
mmont0's Avatar
mmont0 mmont0 is offline
crazyRSX,
Same thing happens to mine. I have a typeS and I just noticed a weird noise coming out of the left hand side of the car. It sounds like it's coming out of the left A/C vent. It happens when I rev around 4000 RPM and hold the revs there. Sounds really weird, but I think it's probably some plastic or something that resonates at that RPM. Let me know if you find out what it is.
Old 05-03-2004, 07:59 PM
checking up on it!
thanks everyone...i have a few leads to what it might be but it will take a while to see how it turns out...some people say timing belts, ac, intake so i'll weed things out and let you know.
wining noise slight when making right turn what is it tire noise or something more tnwhite Dakota 8 06-22-2009 10:04 PM
2001 Impala 3.8 I have no clue what this part is called Amen Impala | Impala SS 2 03-27-2008 04:13 PM
No Clue What Is Wrong krism715 General Discussion 3 06-26-2005 04:11 PM
alright, I finally have a picture of the leak, but have no clue what it is chronofurb Blazer 25 03-14-2005 11:33 PM
No Clue What Is Wrong? SilentAssassin2005 Corsica 10 02-09-2005 03:43 PM
