Go Back   Automotive Forums Car Chat > Dodge > Dakota
View Poll Results: noise in back
noise in back end 0 0%
tires or something else 1 100.00%
Voters: 1. You may not vote on this poll
Old 09-03-2007, 08:34 PM
tnwhite tnwhite is offline
wining noise slight when making right turn what is it tire noise or something more
slight nose when make aright turn sounds like a wining noise but not loud could it be a tire or a more serious problem like bearing or rearend
Old 09-04-2007, 08:15 AM
taillight taillight is offline
Re: wining noise slight when making right turn what is it tire noise or something more
The first answer is yes, but it could also be the brakes. Some sounds are hard to ID. Sometimes it is best just to let it get worse and then you can tell easer.
Old 09-04-2007, 07:59 PM
wayneo69 wayneo69 is offline
wheres the noise coming from font or rear, 4x4 or 4x2
Old 09-05-2007, 08:49 PM
sounds like the rear it is a 4x2
Old 09-07-2007, 08:18 PM
only seems to make noise at very low speeds like when accelarating
Old 09-12-2007, 10:52 AM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
now i would of said tires if you didnt say only at low speeds. i have a noise on my 2000 dodge dakota it started after i went in to waist deep mud drove in to a what i thought was a dried up lake bed actually was really wet under the crusty top. so after that i have had a grindinbg noise and it whines some times as well so i think i got mud in my drum brakes so im gonna take off all my tires and pressure wash the front brakes and the drums on the back il let ya know how it turns out.
Crop circles are Chuck Norris way of telling the world that sometimes corn needs to lie the fuck down
The Great Wall of China was originally created to keep Chuck Norris out It failed miserably
A Handicapped parking sign does not signify that this spot is for handicapped people. It is actually in fact a warning that the spot belongs to Chuck Norris and that you will be handicapped if you park there
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris
Old 09-12-2007, 07:07 PM
sounds like the axle bearings and possibly carrier bearings i would go with the wheel bearings
Old 09-06-2008, 01:15 PM
alexhedge alexhedge is offline
What year is it.If its a 05 to a 07 there is a TSB on the alternator.Thay have to put a washer in behind the pulley to line it up.
Call dealer and give them this reference number 09-003-07
Old 06-22-2009, 10:04 PM
Al_Heb Al_Heb is offline
I have a similar problem. Whines like crazy at 55, completely silent turning right. I have replaced front wheel bearings, drive shafts, shocks, ball joints, rotors, pads, synthetic front and rear diff lube, tranny and transfer case lube job, still the same after all that and $400+ on new tires. It starts at about 15 mph (I can feel it in the steering wheel at this speed, hence the front end bits), gets to be almost unbearable at 55, almost silent (annoying background hum) at 65.
I never thought of the back drums; started in January after I found a water filled hole in the road so deep I plowed the edge of it with the towing hitch.
I'm getting desperate here.
2002, 4X4, 4.7, 110K Miles.
