Old 04-15-2004, 10:00 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Best take off
I'm not sure if anyone has asked this question, but if they did I'm sorry for asking it again. I just wanted people's opinion on what RPM they take off at from a dead stop, without burning their tires to smithereens. I have a 97 GS-T. And also, around what RPM's should I shift to get the fastest time, or to go the fastest?
Thanks
Old 04-16-2004, 04:20 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
rev it up to 7k and drop the clutch! j/k man... around 2-2500 is perfect, but feather the clutch out, dont drop it! same with second... feather the clutch or you will probably spin if your makeing enough power...
as for shifting... this is what i do... its goin to take some getting use to, but so far this is what i got my best time on
1st - redline
2nd - 6500
3rd - 6300
whatever you feel is comfortable, thats what i would do... i'm not saying shift exactly like i do, shift however it feels best to you!
Old 04-16-2004, 03:07 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Best take off
there are many many many threads here and on dsmtuner's website that explain the art of lanching. a veary good answer to your fwd lanch question is answerd by brett http://www.dsm.org/archives/1996/03/...06.txt/12.html
jim http://www.dsm.org/archives/1996/03/19960313.txt/7.html
john
http://www.dsm.org/archives/1998/08/...04.txt/30.html
what you have to understand is how wheel toqure works, and its impossable to know what power curve best fits your shift points without a good dyno. Every car is diffrent, but that should help
Old 04-16-2004, 04:38 PM
Killa_DSM's Avatar
Re: Best take off
Thanks so much guys. Now i should be able to start off faster. Thanks again.
Old 04-16-2004, 08:01 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: Best take off
i launch around 3300rpm to hook up pretty good, and don't drop it, feather it out a bit. i take 1st to redline but if my boost is over 14psi or so i will spin the tires after 5500rpm. i also hold the clutch right over the 100% engage point for quick shifts, i never let it all the way out. 2nd gear is an up in boost from low setting 14.5ish to hi setting 17ish. and all the way to 6200 [60mph-ish] or so, 3rd to 6000+ish depending on the race at that point [100mph+]
but most of all it is practice practice practice... and then more practice. if you can't hook up at 3500rpm try 3300rpm. if you hook up, then mash the gas and spin or hop feather the clutch a bit more. oh ya and practice practice practice
Old 04-16-2004, 08:35 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Best take off
It seems to me that holding the clutch 3/4 in while the crank is spinning from 5000-7000rpm would lead to CW problems. If putting pressure on the crank while starting was bad, that method couldn't be the greatest on the engine. May be wrong though.
Old 04-16-2004, 09:18 PM
EclipseRST's Avatar
Banned
i wish i could launch at 3300... but the tires dont like the 21psi in first! maybe with slicks i can get up to 3k who knows... well see this weekend!
Old 04-16-2004, 09:40 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Best take off
I launch at 4000-4250
For Sale 98 Eclipse GS, 5 spd
Old 04-17-2004, 10:00 AM
slowgsowner slowgsowner is offline
beware the awd wheel hop
nuff said
Old 04-17-2004, 12:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Best take off
I launch at 5500, F wheel hop Seriously, wheephop will break things. Dont make me list all the parts I've gone through. A huge part of reducing wheelhop, and launching well, is setting up the suspension properly. Motor mounts, shocks/springs, camber, etc. I can spin all 4 to redline with no wheel hop. That means less breakage and better 60 foot times. FWD is a bit trickier, you want a stiff ass end.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
best when taking off silverstreek Corolla/Matrix/Voltz 4 09-09-2004 08:49 PM
whats the best way to take off the tps smokeymicpot '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-20-2004 07:12 PM
sluggish to take off, stalls on take off, hard to start pistol_pete Fiero 2 05-20-2004 12:35 PM
Window off Track!! Need to take off door panel... bez '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 12 01-19-2003 03:12 PM
how to: take off brake light off rear deck kenchan Maintenance 2 10-05-2001 05:55 PM
