Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-15-2004, 08:24 AM
christubes christubes is offline
94 explorer has high beams but no low beams
quick question for someone who knows very little about cars. I want to drive my 94 explorer last night but had only high beams, no low beams. all the other lights seemed to be working. Can anyone give me suggestions as to what the problem might be? I also would need to know how to get to the wiring and what not. thanks.
Old 04-17-2004, 07:36 AM
michelq michelq is offline
Re: 94 explorer has high beams but no low beams
i would say most likely bad dimmer switch on steerig calumn
Old 04-18-2004, 10:29 PM
XLT03 XLT03 is offline
Before you spend the money and time on the multifuction switch, I'd try replacing the bulbs first. I had the same problem. Bulb is easier and cheaper. If bulb doesn't do it then go ahead and replace multifuction switch.
Old 04-19-2004, 07:33 AM
srercrcr srercrcr is offline
Fuse?
Old 05-10-2004, 08:02 PM
mindrover mindrover is offline
Dim Lights not working
Try hitting on the side of the console ... just to the right side of the
ashtray. If the lights come on or flicker >>> You have a bad LOM-
Lamp on Module. It will have cold solder joints that need re-soldering.
Somehow ... only the dim light go though this box. Good Luck.
Mindrover - 1996 Ford Explorer EB 210,345 miles and going
Old 05-21-2004, 01:33 PM
tranetech tranetech is offline
dim lights won't work
I just went through the same thing with my 94 Explorer. If both dim bulbs went out at the same time or simply wouldn't work one day when you turned them on then it's not likely a bulb problem. There is a multifunction switch in the steering column that controls the headlights and other signal lights. When it starts going bad the first thing that goes is the dim lights. Eventually you'll loose the brights as well. It's a complicated repair for a novice due to getting into the steering column. I'd suggest biting the bullet and letting a qualified mechanic put in a new one asap before any other lights quit working.
Old 08-05-2005, 05:14 PM
larinjon larinjon is offline
Awesome!
I found the module and resoldered the two contacts - boom! lights again!
Thanks bro!
Old 08-07-2005, 04:55 PM
chr97 chr97 is offline
You saved yourself a pretty penny my sister inlaw had to replace the switch and that alone without labor cost her $100.00
all lights work but low beams??? '00Z71,5.3RcabLbed CR-V 2 04-23-2009 01:31 AM
Already tried some things, but still: Only high beam, no low beam bramcc Tracker 4 11-08-2007 07:35 AM
Hi beams work Low Beams Don't Robbin Grand Prix 1 12-10-2005 12:31 AM
No Low Beams or high beams, but high flash sn95 Taurus | Taurus Wagon 0 06-10-2004 11:14 AM
My low beams are out but my high beams are not, HELP maxima1978 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 11-30-2001 06:27 PM
