Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-28-2001, 04:40 PM
maxima1978 maxima1978 is offline
Send a message via AIM to maxima1978
My low beams are out but my high beams are not, HELP
Just happened, my low beams went out but my high beams still work. I just put those new hyper white bulbs in a month ago, and do not know what to do. Can anyone help PLEASE,
Old 11-28-2001, 04:42 PM
enginerd's Avatar
enginerd enginerd is offline
I had that happen to me and it was a bad switch. You might try to look for loose wiring (sounds like an incompleted circuit).
Old 11-28-2001, 11:47 PM
Y2KevSE's Avatar
Y2KevSE Y2KevSE is offline
Send a message via AIM to Y2KevSE
Your bulb blew.
Maxima.org Admin
\Turbocharged...
Turbonetics ball-bearing T4/T04E 60 trim with polished compressor housing
NorCal Maximas CarDomain Site
CarDomain Site
Featured on NissanPerformanceMag.com
Old 11-29-2001, 12:53 AM
Bucktown Bucktown is offline
Lightbulb
i would just drive around with the high beams on if i were you!
...by the way, that was a joke!
www.ocfederation.com
Old 11-29-2001, 01:54 AM
wikidbwoy wikidbwoy is offline
it could be that the plastic piece that plugs into ur lights has melted and isnt geting a low beam connection but does get high beam. :bandit:
Old 11-29-2001, 05:24 PM
irvine78 irvine78 is offline
Send a message via AIM to irvine78 Send a message via Yahoo to irvine78
just get a new bulb.
Maximadriver.com 2DMAX of Jan/Feb/March
Check out my new homepage!!
http://www.cardomain.com/id/irvine78
mods:Stillen/Premier custom intake, Stillen y-pipe, Stillen front strut tower bar, Stillen rear sway bar, Stillen touring front lip, Stillen side skirts and rear valence, GReddy Evolution cat-back, MSD In-line fuel pump, 2 B&M fuel pressure regulator set at 45psi with VDO read out gauge, Unorthodox racing UDP, Custom 8puck racing clutch/pressure plate, 100shot NOS, Eibach springs, KYB AGX shocks, 300ZX TT front calipers, 12.4inch 3000GT VR-4 cross drilled/slotted front rotors, custom rear superslot rotors with AXISS metal master pads, SS breaklines, red painted calipers, Joshua Tree carbon fiber dash kit, Pacesetter short shifter with MOMO knob, aluminum RAZO pedals, panasonic head unit, Alpine amp and single 12" JL sub, autometer air/fuel, oil pressure guages, Gunmetal Gray 18x7.5 AXIS SE7ENs with 225/40/18 Falken tires/19x8 WORK ESPERIO IIs with 245/35/19 Yokohama AVS Sports, front/rear clear corners, factory fog lights, factory spoiler and 00-01 SE tail lights, AE headlight conversion, JDM style yellow Raybrig blubs up front/rear, APEXi RSM.....shoot...did i leave something out?
Old 11-30-2001, 06:17 PM
1FastMax 1FastMax is offline
if they are xenon bulbs, that happens if u touch there tip.
put ur stock lights back in and see if they work.
if they do, just reclace the xenons.
:frog:
Old 11-30-2001, 06:27 PM
i_rebel i_rebel is offline
Banned
Send a message via AIM to i_rebel
Thumbs up
That just means you need to replace your bulbs . . . they are blown. High beams still work because that part of the bulb is rarely used.
