Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 04-14-2004, 01:22 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Check Engine Light
I have a 99 Malibu 2.4L edition. I installed an amp and subwoofer yesterday. I started my car this morning and drove to the store with out the check engine light on. Then started it to come home and the check engine light came on. Any ideas, the only thing I did to the engine compartment when I installed my amp is run the amps power wire to the battery. Thanks in advance
White 07 STI, Bone stock for now
Old 04-14-2004, 04:22 PM
e2helper e2helper is offline
Re: Check Engine Light
It is the Check Engine Telltale, right? The Amber/Yellow indicator with a little picture of an engine over on the right side of instrument cluster?
Maybe you have a loose battery cable now and and voltage is low. Or maybe you recently filled gas tank and didn't tighten gas cap enough - it could be lots of stuff.
This telltale often might take a couple ignition cycles for telltale to come on or go off so it might not have happened exactly when you thought.
Old 04-18-2004, 03:41 PM
ViperJ's Avatar
UPDATE: I took it back to the dealer and had them check it. I turns out the ITA gasket was bad. That is just an intake gasket. So $94 later my car is running great.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
