Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-14-2004, 12:30 PM
88zccivic 88zccivic is offline
please help got turbo on
this is what i have
88 civic with dohc zc swap
t25 off of an eclipse
hf manifold
2" piping
stock actuator (with treaded adjuster)
aftermarket intercooler
450cc injectors (dsm)
apexi safc2
heres the proplem i cant boost over 1 psi (acorrding to my safc)
but my wastgate opens at 4000 rpms witch should be at 6-8 psi. i looked for a leak in the piping but couldnt find anything and the car is smoking and not to mention my new clutch slippes at 4000 rpms
and when i let off the gas my turbo sounds like it has a dove in it (bird)
the cor doesnt fell like it is boosting more than a pound
please reply
Old 04-14-2004, 04:50 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: please help got turbo on
1st off is it a new safc ? did you check the turbo out before install ? how many miles are on the turbo ? what kind of fuel are you running ? i think i know what your problom could be..but i ( we ) will need a lil more info
Old 04-14-2004, 05:22 PM
yes its a brand new safcII the turbo had a littel shaft play not hitting the sides or anything im running pump 93 im not for sure the miles on the turbo and the smoke comming out is white
Old 04-14-2004, 06:10 PM
also i only hit that 1 psi when the engine is working hard ,going up hill or going slow in a higher gear
it wont boost in first gear at all
Old 04-14-2004, 07:10 PM
SleeperCivic SleeperCivic is offline
Definitely sounds like a massive boost leak to me. If the turbo was really bad off, you could pull the downpipe and/or intake pipe off and more than likely see oil. I bet it's either a busted coupler, lose coupler, or a busted FMIC. Also, I didn't see a BOV in your list, so that would be the "dove" sound you hear - compressor surge.
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 04-17-2004, 01:03 PM
ok i cant find a leak any were and my pipes are all open but the pressure is still coming to the turbo
i do have a bov but it hasnt opend yet because im only hiting 1 psi it sounds like 8 going through the turbo when i let off. i have a fmic so i took that off to see if it was restricting it and just put a pipe in but still the same thing im lost
Please help me i need the answer to continue.. get_z24turbo Cavalier 1 07-23-2010 11:38 AM
Please help! I want mods on my lancer T_BONE Lancer 2 07-13-2010 12:39 AM
96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do! Jinisu2 LeSabre 6 05-13-2010 10:53 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
please help with turbo not getting enough boost kyrx7 RX-7 6 06-14-2004 12:11 AM
