Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-13-2004, 11:06 PM
Romeosback Romeosback is offline
Send a message via AIM to Romeosback
Question Speedodmer Problem
I just bought an 88 prelude 4ws,and i did an 89 2.0L motor swap and a tranny swap But when i got the car back i noticed that the speedodmetor wasn't working.......What do i do?
Old 04-14-2004, 01:34 PM
88 ROCKET 88 ROCKET is offline
Re: Speedodmer Problem
They didn't hook up the cable, it plugs into the top of the transmission on the drivers side, or take it back to whoever did the work and tell them to hook it up!... 15 min. job.
Old 04-14-2004, 06:09 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Speedodmer Problem
Yes the cable can easily come out if the clip is not installed right. Had the same problem on a friend's car about a year ago. It is a easy fix.
Old 04-14-2004, 09:55 PM
Thanx guys......... Would i have to take out the tranny or just stick it up on a lift?
Old 04-14-2004, 10:03 PM
whtteg's Avatar
I am 90% sure that the speedo cable goes into the tranny on the top towards the firewall. But no you don't have to take the tranny out. Go here and download your manual it will help you out both now and in the future.
http://www.icelord.net/honda/repair/
Old 04-16-2004, 12:41 PM
Ok i connected the speedo cable but im still not getting a reading on the gauges, How do i fix that problem?
Old 04-16-2004, 02:44 PM
Did you make sure the cable is seated in the spline of the gear properly?.... You need to ensure the cable is not broken as well. Disconnect it from the back of the spedometer by laying on the floor under the steering wheel and reach up behind the dash and disconnect it... drive the car and make sure the center of the cable is turning, if not the cable may be broken and that is why it isn't working.... Or you may just want to order a new cable and rep[lace the whole thing if you plan on keeping the car for a while. there might be a problem with the speedometer itself... although highly unlikely... troubleshooting just takes time so be PATIENT and work through it...
Old 04-17-2004, 02:10 AM
Thanx for the help
Old 04-19-2004, 07:40 AM
DID you get the speedometer fixed?... let me know what the problem was. I always like feedback as to what fixed the problem... Thanks.
My little 88 lude is so darn much fun to drive and with the 5-speed... she get's up and "hauls ass". Like I told you earlier, 1988, 246K miles, and she runs like a rocket but requires TLC and "tweeking" every now and again. Keep up on the regular maint, and 3K mile oil changes and your honda will run 300-500K miles...
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
