Old 04-13-2004, 10:09 PM
shady8705 shady8705 is offline
Send a message via AIM to shady8705
tranny problems?
I have a 96 taurus gl and when i take it out of park and shift into drive the whole car jerks and also when its shifting gears. Tires will sometimes chirp when shifting into 2nd. These problems usually dont happen when the car is driven for a while what could the problem be please help. Please email me with all suggestions at [email protected] thanks alot and please help me
Old 04-14-2004, 09:09 PM
dukeofchurchill dukeofchurchill is offline
Send a message via AIM to dukeofchurchill
Re: tranny problems?
This sounds like your main oil pump in the tranny is not building up enough pressure. That can be caused by a number o things. But here is a good place to start. 1) visually inspect if for external leaks 2) do a pressure test on it. 3) Also hook up a scan tool to your OBD and what messages it gives. If all of those check out. Then there is a strong chance that there is a problem associated with the valve body.
Now if you have been doing a good job of keeping the ATF changed. You might have a chance of finding a good rebuilder. If not get ready to replace the tranny.
Russell
PS. i ain't no expert. But am in a Tranny Class at the local community college this semester. So I am sure you can find better people to answer this question.
Old 04-18-2004, 02:51 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
well, could be a partially plugged filter. Try changing the atf and tranny filter. The tranny does not have enough oil volume to prefill the next cylender when shifting. Now the tranny could also be in dummy mode. If the PCM detects torque convertor slippage it will up the line pressure and there will be hard shifting. Try take the battery out for about an hour, and reconnect it and see if it still shifts hard.
99 Pontiac Montana Tranny problems? wilson8260 Montana/Montana SV6 9 12-22-2009 09:16 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 03:41 PM
tranny problem or engine/tranny mount? jbjslambert LeSabre 4 12-13-2008 11:03 AM
Tranny problems and maybe other problems. P0700, P0740, P1776 SupraSeth94 Caravan | Voyager 15 06-14-2007 06:24 PM
