Old 04-13-2004, 07:38 PM
troy808 troy808 is offline
Help!! f900 Click and no power
I have a f900 w/8.3 cummins boom truck. I am having some trouble with starting. This truck has two 31 series battery in series with and extra negative post for starter ground. the extra post has power coming back to it instead of it being ground.
could it be a bad starter or bad ground connection or open somewhere?
If i am in the wrong place I am sorry....
If someone can help..I would appreciate it
Aloha
Troy
Old 04-15-2004, 07:39 PM
mayville1 mayville1 is offline
Send a message via AIM to mayville1
Re: Help!! f900 Click and no power
You need a new starter.
Ive got a F-250 1997 And one day it just wouldnt start and a new starter fixed it.
It was the same problem I turned the key and it just clicked.
Old 04-18-2004, 01:56 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
we can not say you need this with do diag. First off, could be a bad starter, cables, or selonoid. Take a voltmeter and see if you have power on the side of the selonoid going to the starter. if you don't bad selonoid, if you do good. Have someone turn the key so it clicks and put your positive on the large wire connecting to the starter, and the aux. ground and see if you have power, if you do, double check connections and replace starter. If you don't check the cables. Diesel starters are expensive, have to make sure you are replacing the right thing.
Old 04-24-2004, 12:12 PM
ModMech's Avatar
ModMech ModMech is offline
Turn on the headlights, if they quit when you attempt to start and your voltage gauge goes way down, most likely you have a bad ground or cable. It could also be a bad (shorted) battery, with two you cannot tell easily except by a load test.
02 Town and Country Lmt, FWD - Clunking from front end and power door problems confused81 Caravan | Voyager 12 08-06-2010 10:19 PM
2000 Pontiac Sunfire GT Randomly Loses Power Karan Cavalier Problem Diagnosis 19 04-30-2009 06:36 PM
Need Help Check engine and Power down Lights on jdmcivic1999 Rodeo | Passport | MU 1 03-01-2007 09:13 PM
Need Help, Engine Missing and power window will not work Rolm Grand AM 4 10-01-2006 10:16 PM
Help Silverado brake and power steering fail rtavi Silverado 0 09-28-2004 08:05 PM
