Old 04-13-2004, 04:12 PM
dev3768 dev3768 is offline
Talon motor
Ive got a 90 talon and its runnin on 3 cylinders. I'm pretty sure its the rings since the head was replaced 5k miles ago, should i swap it out or put in new pistons, also can i just replace the rings? or the pistons w/o replacing all the bearings and gaskets
Old 04-14-2004, 12:08 AM
coldhell9 coldhell9 is offline
Re: Talon motor
First off are you sure you are getting fuel and fire to all four cylinders? And if you are going to tear down the block that far you might as well just get a rebuild kit!
blinkers quit 97 eagle talon chucky123 Eclipse Problem Diagnosis 0 11-24-2009 10:45 PM
99 passenger window motor/regulator SlimJimRD Windstar 8 07-20-2009 05:44 PM
Is General Motors - Chevrolet going Bankrupt? Zaara Spark 2 06-01-2009 05:57 AM
95 talon wont start - no fuel pressure eclipse787 Engine, Transmission and Drivetrain 2 05-08-2009 09:06 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
