Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 04-13-2004, 03:11 PM
WhitePassat01 WhitePassat01 is offline
Spark Plugs
I was wondering if there is anything tricky to changing the spark plugs on my 2001 Passat wagon? Any help is appriciated. Thanks!
Old 04-13-2004, 08:11 PM
boschmann boschmann is offline
Re: Spark Plugs
On 2.0 it's easier to take off the air plenum first, but supposedly not necessary (I find it easier). On VR6 alot of the typical fatter plug sockets won't fit down the plug hole, some vendors sell a special socket just for this. Make sure you use a high quality plug.
Old 04-14-2004, 11:03 AM
Spark Plugs
Thanks for the help... We have a 2.8. Do you think it would be the same thing as the 2.0? Thanks!!
Old 02-26-2005, 08:20 AM
fastissimo fastissimo is offline
Anyone have a virtual Passat Manual and can cut and paste the section for changing the spark plugs and post it here? If not give me your 2 cents on changing the spark plugs on a 2003 Passat 1.8 Turbo. Thanks!!!
Old 02-27-2005, 02:53 PM
Re: Spark Plugs
It's not as hard as on a 2.0. It has a coil over each plug so you have to remove each one to get to the plug, but it's fairly easy.
Old 03-19-2005, 01:04 PM
zoom14151 zoom14151 is offline
Re: Re: Spark Plugs
Is it hard to remove the coil without breaking them or do you need a tool.
Old 03-19-2005, 04:54 PM
Re: Spark Plugs
Some of the early ones had a torx or hex bolt, but most are fairly straightforward.
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 12:23 PM
