Old 04-13-2004, 02:54 PM
94TramsAmGT 94TramsAmGT is offline
Problem with 77 f-250 w/ 429
Hi i have a 77 f-250 show truck with a 429 and i have an electrical problem where my lights just constantly pulsate. I have replaced the battery, alternator, ignition coil, brain box, solenoid but still no luck. I would GREATLY appreciate anyone out there that has any suggestions. I am getting very frustrated.
Old 04-18-2004, 01:58 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: Problem with 77 f-250 w/ 429
What exactly do you mean by pulsate? On and off, and the dim kinda? Check the grounds and take a volt meter and check the light connection. Sounds like a bad ground, so ground your volt meter to your battery and see if you have a varying voltage. if you don't, check all the grounding straps.
F-250 won't turn over. please help. 907fordfanatic F Series 3 01-07-2010 07:44 PM
Various problems with my 1992 Nissan Sentra XE (4 door) benenarmor Sentra | 200SX (USDM FWD) 0 10-11-2009 11:32 AM
fitting different rims to old F-250 steve f. F Series 1 02-16-2009 10:44 PM
egr problem 98 e 250 4.2 engine tom732 E Series 1 03-08-2008 01:46 PM
common problems 89 f-250? Truckworld F Series 0 01-24-2005 04:40 PM
