Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 03-04-2008, 09:08 PM
tom732 tom732 is offline
egr problem 98 e 250 4.2 engine
I Have 98 E-250 Ford Van 4.2 V-6 Has Misfire Code 305. Runs Rought Off Idle About 900 -1200 Rpm Has New Wires ,plugs Ck. Has Spark At All Cylinders When Running Bad , Found That When I Pulled Vac. Line To Egr Misfire Is Gone . My Question Is Why Is It Setting Missfire Code Not Egr Codes And What Is Causing The Code ,egr,egr Vac Sensor ... Thanks Tom
Old 03-08-2008, 01:46 PM
Nivek1 Nivek1 is offline
Re: egr problem 98 e 250 4.2 engine
I would say you are getting a random misfire code..is that correct...If u can get your hand under the intake...follow the PCV tube to where it goes into the intake, the elbow could have a hole in it...u won't hear it ..hissing but its there...
Of all the things I lost ....I miss my mind the most.
