Old 04-13-2004, 01:25 PM
codboy codboy is offline
starter motor
I need to change out the starter on my 3.1 1995 lumina apv, any hints on this, looks like a hard one to get at.
Old 06-09-2004, 04:46 PM
Slammerz Slammerz is offline
Re: starter motor
Just did it on my 96 olds silohette, not to bad. First remove the plastic shield around the flywheel end of the starter. Then you have to have a 5/8" end wrench to get the bolt above the frame crossmember, (A ratcheting box end wrench would probobly make this alot easier, worth the cost of buying one) other than that a 5/8" socket with a 6" extension for the other bolt. Remove the bolt above the frame first, and be sure you install the new starter with that bolt already in the starter, no way to install it once the starter is in there.
Starter motor to starter solenoid wire Plymouth Voyager 1993 Voyag1993 Caravan | Voyager 3 02-13-2007 12:52 AM
Turbo Timer Problems > Starter Motor Macker Engineering/ Technical 0 06-22-2003 12:02 AM
CRX starter motor krnlpanik '88 - '91 Civic | CRX | Wagon | Shuttlee 2 10-19-2002 08:01 PM
May need new starter motor. Where to get? PatrickG20 General 3 03-06-2002 02:10 AM
Starter Motor died today nismo_gt Engine 7 02-28-2002 05:49 AM
