Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-13-2004, 09:26 AM
cheetahcat cheetahcat is offline
Unhappy Coolant loss
Hi, I'm new here and I could use some help please.
I have a 1996 Regal 3800 v6 that is losing coolant somewhere. My husband is a very good mechanic but we have been unable to locate where the coolant is going. There is no visible loss but after several days the low coolant warning light comes on and the coolant level is very low. Does anyone have any suggestions?
Thanks.
Old 04-13-2004, 01:21 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: Coolant loss
check your oil, does the color look distorted? does it look milky? Is so, your intake gaskets, or head gaskets may be at fault.
Old 04-13-2004, 08:05 PM
Thanks,
The oil looks fine. No discoloration or milky look to it.
Any other ideas?
Old 04-13-2004, 08:29 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Coolant loss
Your engine is burning it! Remove your throttle body and look inside the intake with a flashlight looking for coolant!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-14-2004, 12:22 AM
Thank you,
We will check it ASAP. If there is coolant????? (I take it this would be really bad.....)
Thanks again.
Old 04-22-2004, 12:36 AM
gmcarguy gmcarguy is offline
Re: Coolant loss
Your problem is probably in the plastic upper intake. Huge problem with GM 3.8's. They leak at the frt of the manifold behind throttle body. I bet there will be signs of coolant on the frt of the lower intake.
3.8 coolant loss help lesabre LeSabre 21 12-23-2005 03:55 PM
2000 grand caravan mystery coolant loss rykerjenbob Caravan | Voyager 3 01-22-2004 03:58 PM
coolant loss Chad S. X5 1 11-23-2003 03:50 PM
previa coolant loss gap Previa 1 08-19-2002 04:46 PM
Coolant loss geoff200 Maintenance 6 07-23-2001 06:01 PM
