Old 04-13-2004, 12:03 AM
bad137 bad137 is offline
New tire size and rubbing HELP!
I have a 2004 Tahoe LT 4x2. Stock tires were 265/70R16. I just replaced them with 275/55R20. Doing the calculations, the new tires were very close in size to the 265/70R17 tires you could get as an option, so I didn't think the larger tire size I added would be a problem. After putting the wheels on tonight, the front driver's tire rubs the plastic in the front of the wheel well, just aft of the winshield washer fluid tank, when turning. The plastic looks like it sticks out a distance and the tank is not in the way. I thought about grabbing the dremel and cutting it off, but figured I better ask first. With my tire size now being so close to the 17" tires I didn't think this would be an issue. Any help?
I also planned to take it to the dealer to have them reprogram the computer to the 265/70R17 tire size, since it's less than 1% different from what I put on. Thanks,
Brett
Old 04-15-2004, 06:38 AM
andjh123 andjh123 is offline
Send a message via AIM to andjh123
Had the same problem in an old 95' I used to own, it was a 4x4 however. If I remember correctly, those plastic pieces in the front wheel wells just bolt in with one or two bolts. Since yours is an '04 and I'm not too familiar with those, check to see if you can unbolt and remove the plastic before you go to grinding--you may be able to just remove those pieces without an unsightly result and put them away somewher--retaining the option of putting them back on should you ever go back to smaller wheels/tires (only to lose the pieces after a few weeks which defeats the whole purpose of unbolting them as opposed to grinding, hmm....)
help w/ tire sizes and new wheels for 90GT GhettoPop Mustang Talk 0 08-21-2007 01:44 PM
Wheel size and rubbing 94DXSiR RX-7 1 07-06-2005 10:26 AM
Engine Swaps,wheel and tire size,and Rear brake disc conversion LX sleeper Escort 1 07-11-2004 01:51 PM
Help Tire Size And Drop? mistadee77 Tires and Wheels 1 08-07-2003 12:05 PM
i need some help with tire sizes and such tony350ss Tires and Wheels 1 10-27-2002 11:22 AM
