Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-12-2004, 09:45 PM
bizjet604 bizjet604 is offline
front rotor noise?
00 Corolla, noise coming from wheels sounding like brake dragging(pronounced in turns at slow speeds). Just replaced front pads and had rotors turned. Problem still persists. Back brakes? Any ideas? 27K miles and auto. E-brake seems to be fully releasing.
Old 04-13-2004, 09:23 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: front rotor noise?
Sounds like warped discs.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 04-26-2004, 10:42 AM
Re: Re: front rotor noise?
Just replaced discs, problem still persists.
Old 04-27-2004, 02:29 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Calipers good, pads OK? Bled the lines etc?
Old 04-27-2004, 07:51 AM
winner007 winner007 is offline
brake noise
U have to get used to that for a while i think. Also some brake pads are noisy because of their material. Asked them what kind of material they are using when they replaced your brake pads and rotors. Did they machuien your rotors or get u new rotors? That should be a normal. Are u sure is coming from the front? If it is coming from the back u will need to clean and adjust the rear brakes.
Old 04-30-2004, 12:00 AM
front rotor noise problem solved........scrubbing sound coming from tires against the rim. spray silicone around bead area of rim and noise is gone.
Old 04-30-2004, 10:34 AM
woodsonj3 woodsonj3 is offline
I am having the same problem on a '95 Corolla. Took the pads off and resurfaced. It went away for about a week then came back. Only doing it on one side. I'm wondering if it is shims? Are there pad/rotor compatability issues with this car. I had a '84 Corolla that was real temperamental about brake pads. Seems like it only liked Toyota pads.
front clicking noise. wheel?? sohcd16 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 10-24-2010 08:53 PM
Brembo front rotors..new style.pics wirewheel99 GTRA / GTWS / GTS 2 08-06-2010 02:23 PM
90 GC front end noise Selec-trak benjaminbunny Grand Cherokee | Grand Cherokee SRT8 1 12-20-2009 06:00 AM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
