Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-12-2004, 11:12 AM
2000_gs 2000_gs is offline
faster acceleration
Whenever i look at Integra LS dynos, i notice that they don't read their peak until around 6K to 6.2K RPM... unlike others that reach their peak sooner like eclipses, accords, etc.
is there any way to do this for the integra? or would i need some gear box to adjust the ratios? i dunno what i'm talking about, just throwing ideas in the air....
Old 04-12-2004, 11:43 AM
Oldteg Oldteg is offline
Re: faster acceleration
cams and or cam gears would help you with more power down low. These motors like high R's. A cold air intake would help a little bit down low also.
Old 04-12-2004, 11:49 AM
hahaha.......nice!
Old 04-12-2004, 01:54 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
Recess the floor so you can push the gas pedal down further.
Why does peaking at 5000 or 5500 rpm matter? It just means you have less rpms to work with.
Old 04-12-2004, 03:29 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: faster acceleration
Cams with greater lift and duration move your power up further in the rpm range. They will not help the low rpm power. The best thing to do is a B20 swap it is cheap and easy, you can get them for around $600-900. And they are a direct bolt in and you use the same ecu. Just swap the intake and exhaust manifolds form the B18B1 and you are set.
Old 04-12-2004, 04:27 PM
WOW, thats a cheap date. What is the B20 out of? It bolts right in? That tweeks my intrest a bit. How much power does a B20 put down?
Old 04-12-2004, 05:50 PM
KounT KounT is offline
Send a message via AIM to KounT Send a message via MSN to KounT
will a b20 bolt directly into a 91 ls or would it need a new motor mount
Old 04-12-2004, 05:58 PM
whtteg's Avatar
Yea it will bolt right into a 91 ls. The same thing applies to you though, you need to swap your intake manifold and exhaust manifold onto the B20. I would suggest though to get a Skunk2 manifold b/c the 91 ls manifold does not flow well at all. Or if money is tight get a 94-95 ls intake manifold that will help with the flow a little.
Old 04-12-2004, 06:07 PM
whtteg's Avatar
The B20 is from the CRV. It is basically the same exact motor as you have, except it has a bigger(84mm) bore vs the 81mm bore of the B18B1. Now there are some thingsd to keep in mind when geting a B20, there are different ones. Check this link out http://hybrid2.honda-perf.org/tech/b20/b20tech.html
Old 04-13-2004, 11:14 AM
wow... thanks for the answers guys...
Old 04-13-2004, 02:23 PM
i started a new post asking about the b20 swap.. and this is what i got...
b20 swap post
accelerator not responding buddahkat06 Accord/TSX/Accord Hybrid 2 02-26-2009 04:05 PM
Loses power under acceleration MikeS144 Metro 13 02-15-2009 07:56 PM
98 camry needs faster acceleration and body kits cheap!! brickwall88 Camry/Camry Hybrid/Vista 2 06-23-2005 03:48 PM
Faster Acceleration Koojo Engine 48 11-03-2004 05:42 PM
faster acceleration SnowboardGurly '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 05-22-2003 09:30 PM
