Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 04-11-2004, 10:30 PM
Asianprep Asianprep is offline
Check engine light is on...etc
my 97 galant got a check engine light on b4 i got a new battey installed. After i changed battery the check engine light went off. On the same day i went to get my oil changed the light went back on. I thought i needed to flush my radiator since the mechnic said it is recommended. Well today i flush the radiator and got new anti freeze in the system and the check engine light is stillz on....any peeps out there might have a clue???
Old 04-27-2004, 02:18 AM
azriel azriel is offline
hello,
what you can do is to run some diagnostics on your car. a check engine light means your ecu detected an error.
there is an ODB terminal underneath the dash (driver side) and its trapezoidal-shaped terminal.
what you do is locate pin#1 and connect it to ground. you will notice that check engine light will start to flash (it consist of long and short pulses).
count the number of long pulses (indicates 1st digit) the count the short pulses (indicates 2nd digit).
if you get two long pulses and 3 short pulses... then your error code is 23. look for the meaning of trouble code (i remember this is crank position sensor error).
you can also get more than one trouble code. different trouble codes are separated by relatively long pause of pulsing before another set of error.
this is more likely the first thing that you should do to pinpoint what exactly your check engine is telling you.
hope this helps.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
