Old 04-11-2004, 02:17 PM
dan89crxsi dan89crxsi is offline
Banned
Question b16a1 ???
should i put a b16 or a b17 in mi 89 crx si? i was thinkin about putin in a turbo a lil later could both engines hadle the turbo on everyday use?
Old 04-11-2004, 05:59 PM
civicracer388 civicracer388 is offline
Both of the engines could handle the boost as long as your running at low pressure like around 7 psi. If you want to go with higher boost, you'll have to start replacing internals. I.E. low compression pistons, rods, head work. Don't use a B16 or B17. If your gonna go with forced induction use a B18B (LS engine) or B18C1 (GS-R engine). Their natural low compression makes them second to none for turbo.
Old 04-11-2004, 08:18 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
i would go with the b16 due to the better r/s ratio. and yes, the b16 can handle moderate boost on stock internals for daily driving.
As American As A Burrito!
USDM 4 life!
Old 04-11-2004, 08:24 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: b16a1 ???
plus b17 are $$$$ and you could hook up a b16 for price of b17
Old 04-11-2004, 10:04 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Re: b16a1 ???
Not neccesaraly, i got my b17a1 from a 92 gsr(wrecked) for a little under 1200 with everything. Oh yeah and then i turned around and sold it for 2000. yeah.
If youre gonna boost go for a 1.8 liter b-series. Perferably a b18a or b18b due to low compression.
Old 04-12-2004, 12:44 AM
SiZ's Avatar
SiZ SiZ is offline
Re: b16a1 ???
If you're going with a small amount of boost (6-8psi), then really the B16 is just as good a canidate for the turbo as any other motor. Once you start to boost more, then its going to be expensive on either motor because you're going to have to run a better engine managment system ($). So really, its all the same.
Boosted B16s = quick
"The nympho of info, I'm fuckin' what ya heard"
Need help identifiying jdm b16a1 sensor! zipperheadk Engineering/ Technical 12 03-13-2008 01:27 AM
What Is Needed To Get B16a1 Into High 13's All Motor? UMREX '71-'87 Civic | CRX 14 03-11-2002 12:37 AM
b16a1 in 5th gen. hatch? Poweredbyhonda '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 02-19-2002 11:20 PM
