Old 04-11-2004, 01:23 PM
jamesgky jamesgky is offline
Unhappy 97 cavalier problems
I have 2 problems as of right now. The first is a power loss when I apply the brake. Occasionally the lights will dim and the radio will drop out. It may be due to the fact that I have an 800 watt amp hooked up, do I need to buy a bigger alternator, or is it something else?
The second problem is a squeaking noise when I turn the wheel or hit a bump. It had this problem when I bought it, but when I went through the recall on the rack and pinion gear it stopped. Despite the fact that I have new struts it recently started again. What could cause this? Any information would be greatly appreciated.
Old 04-11-2004, 02:14 PM
michelq michelq is offline
Re: 97 cavalier problems
sound like loose connection check battary cables starter wires and body ground wire
you do not need high amp alt
Chevy Cavalier 2001 Cooling System Problem getwilde Cavalier Problem Diagnosis 6 09-02-2011 09:02 PM
puzzling problem with my cavalier sfb313 Cavalier Problem Diagnosis 2 09-26-2010 04:09 PM
95 Cavalier Master Cyl/ABS problems HebrewDude Cavalier Problem Diagnosis 1 08-02-2010 09:55 PM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
