Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 04-10-2004, 08:22 PM
walter_w walter_w is offline
'91 Galant won't start
I have replaced my starter and my main brain as dealership mechanics said and still can't start my car. Just looking for any info on what else i could be missing. Oh and new fuel pump.
Old 04-13-2004, 07:21 PM
dev3768 dev3768 is offline
Re: '91 Galant won't start
well you should check your distributor and all wires, plus ignition coil. check the battery, plugs and otherwise ur screwed- does it turn over?
Old 04-14-2004, 12:41 AM
Battery is brand new. It does turn over but after testing eack wire to see if i get spark to plugs i only have spark to coil. got new cap and rotor on order hopefully that will fix it.
Old 04-14-2004, 08:10 AM
it sounds like your ignition coil needs to be replaced, like 30 at advanced auto
Old 04-21-2004, 03:00 PM
Looks like Rotor was fried and sending the spark back to coil instead of wires. Plugs got fouled from all the trying to start. New plugs and wires and it should be good as new.
Old 05-04-2004, 03:05 PM
'91 Galant has all the basics but won't fire up.
Ok new parts list: computer, distributor, plugs & wires, fuel pump, cap & rotor. I have spark and fuel and it will do nothing but turn over. If anyone has any insight please let me know.
Old 05-04-2004, 06:48 PM
zebra_9 zebra_9 is offline
Re: '91 Galant has all the basics but won't fire up.
Don't quote me, but take into consideration that the ECM could be bad.
These are about 100 dollars at say AutoZone, Napa, etc. A search on web on Electronic Control Modules, shows they usually last 3 to 5 years, especially on 89-94 models.
It is located on the head intake to the fuel injection on top side of the block. Located on a small metal bracket, a clip plugs in. Did car just suddenly die? Let me know how it goes if you replace it.
Old 05-05-2004, 02:42 AM
I went into the store one day came back out and car never started again. The only trouble I had ever had was car would sputter at 2400 rpms. After talking to a certified Mitsubishi mechanic he said computer was the problem no question. Well he was wrong.
Old 05-05-2004, 02:53 AM
I did a search on ECM and that is the computer that I have already changed out. It was behind the glove box, and boy the price on that was a tad higher than $100. It was $375 for a rebuilt.
Old 05-05-2004, 02:22 PM
YankeeKid2k3 YankeeKid2k3 is offline
are u sure u have fuel pressure? if not i would check the pump or the pump relay. get a pressure test done, just to be sure.
Old 05-06-2004, 11:31 AM
I just wanted to let you know that the control module that I tried telling you about is actually called the ICM which is the Ignition control module.
You can see where the clip plugs into the small computer (ICM). It is on a metal bracket. It's easier to pull both bolts on bracket. Usually if computer in dash goes, there can be a funky, burnt, almost dead fishy smell. My brother inlaw has 1990 Galant, spent bunch of money trying to fix. I suspected the control module but didn't know which one. Had to have car to worksite to diagnose.
Old 05-06-2004, 01:52 PM
I am having another certified mechanic check it out. Thanks for the info I will keep the ICM in mind.
Old 05-08-2004, 08:08 PM
wandered how things went. Or if they went at all. I know how frustrating it has had to of all been, If fixed, what was problem?
Old 05-17-2004, 02:23 AM
Well this is what I have found out. We checked the injectors and 3 of them are on full blast the second I turn the key. 2 of them were shooting full streams 20 ft. I have replaced the injectors but whatever controls the impulses for them is out seeing how they are on full time instead of shooting when told to. We light tested them and 3 are on full time 1 isn't working at all. The distributor is not the cause of this we tore apart the distributor and took it out of car and injectors still did same thing. As of now I have no idea what is controling the impulses to the fuel injectors so any insight would be greatly appreciated.
Old 05-24-2004, 02:19 AM
bunalmis's Avatar
bunalmis bunalmis is offline
Last week my car stoped and not worked.
My friend find the problem. Gear of Distributor mils broken.
(So this gear coupled by trigger gear)
We didnt find orginal part and we weld it. Now may car working.
Your problem may be same. Open the distributor cover and turn the
moving contact of distributor by your finger. You have same problem if freely turn. (Normaly this contact dont move by hand.)
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
'91 Civic Won't Start number4t1 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 10-21-2007 03:34 PM
1995 galant won't start. eithet Galant 0 07-18-2007 09:10 PM
92 Galant won't start!! rdway60 Galant 1 03-16-2004 05:07 PM
'91 escort won't start lovess Escort 1 10-17-2003 06:27 PM
