Old 04-10-2004, 07:04 PM
ManOmoon ManOmoon is offline
Unhappy 2001 Camaro oil drain plug stripped?
I recently bought A 2001 Camaro and I'm trying to change the oil but the oil drain plug just spins in either direction. Is the oil drain plug stripped? If so how do i remove it? Help !
Old 04-10-2004, 07:46 PM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
a pair of vice grips.. lock em on to the plug and try to spin as you pull out.. if the plug is stripped... just replace it along with a gasket.. if ur pan is stripped.. they sell tempoary plugs... you put in the hole and tighten...the seal squeeses itself onto the pan.. creating a ...seal.. most likely its ur plug
2001 Elantra Oil Drain Plug bowl2286 Elantra | Avante 6 10-15-2007 05:59 PM
2001 Blazer Oil Drain Plug Gasket??? spunger S-10 2 08-10-2006 02:09 PM
stripped oil drain plug baldhead Magnum | Magnum SRT8 3 02-23-2006 06:35 PM
