Old 04-10-2004, 12:55 PM
jhood23 jhood23 is offline
carbon fiber hood question
i ordered a carbon fiber hood for my 96 honda civic, it uses the factory latches on the car but has to be pinned down on the front, now my dad owns a body shop but he has never drilled a carbon fiber hood, i here it is pretty difficult. Is there any way around that like being able to use the latch at the front.
thanx in advance
Old 04-10-2004, 01:13 PM
SPOONFED_VTEC SPOONFED_VTEC is offline
Hoods
Two of my friends have cf hoods and they both use the factory latches.
The pins are just for looks in my opinion. That's just my
Old 04-10-2004, 02:57 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: carbon fiber hood question
Where did you order your hood from? Most hoods these days come with holes drilled so that you transfer the front latch from your factory hood to your CF one.
Empty Pockets Racing Member #1
Old 04-12-2004, 10:20 AM
carbon fiber hood
well i ordered it from a store here in new york called east coast speed, it uses the stock latches and the hood is predrilled for that but tehre are no holes int he front for pins so i have to drill them, i was wondering if anyone had a tutorial or something on how to install hood pins, like how to drillt he holes and where the pins mount to under the hood?
thanx fellas
Old 04-12-2004, 12:16 PM
HamsterStyle HamsterStyle is offline
Send a message via AIM to HamsterStyle
PINS ARE NOT JUST FOR LOOKS!! WE ALWAYS JUST MEASURE WHERE WE WANT THE PINS, MARK IT THEN USE MASKING TAPE AROUND IT, SO U DONT SCRATCH THE HOOD. IF YOU WANT TO TRUST SOMEONE ELSE'S LAY UP WORK TO HOLD YOUR $500 HOOD DOWN WITH THE LATCH GO AHEAD. I WOULD USE THE PINS AND THE LATCH.
JUST MY .02
tommy
Original PH member since May 2000.
Old 04-12-2004, 03:35 PM
GScivic7's Avatar
thanx fellas
oh okay, I misunderstood. Well, can't help you there sorry.
BTW: Hamster, turn off your caps lock
Old 04-12-2004, 11:47 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
My vis hood came with the proper hardware and had all the components of a stock hood such as the d-latch holder in placer thingy.
Hood pins must be used for road use. I have seen it too many times a hood flying off of a car on the highway for not using hood pins.
Carbon Fiber Hood Question 94Z28Conv. Exterior | Wheels | Tires 3 06-24-2007 03:42 PM
VIS Carbon Fiber Hood Question WickedMethod Exterior | bodykits | Lighting 6 12-23-2004 02:00 PM
Carbon fiber hoods question!!! smokeurass Off-Topic 9 12-06-2003 02:26 PM
Question About Carbon Fiber Hood eclipse2quick21 Exterior | bodykits | Lighting 9 08-13-2003 09:10 AM
Carbon Fiber Hood Question olz_chick Graphic Manipulation 8 09-23-2002 04:45 PM
