Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 04-09-2004, 02:18 PM
Dead-Wyrm's Avatar
Dead-Wyrm Dead-Wyrm is offline
Send a message via AIM to Dead-Wyrm
2jz gte in a no turbo
can you put a 2jz gte in a non turbo supra?
Thanks TheNotoriousMogg for the Sig!
Old 04-09-2004, 02:21 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
It's possible, but it does take a lot work, being as the tranny's are different and i don't know if the rear ends are the same and also the computer will be very different.
Old 04-10-2004, 11:12 AM
Dead-Wyrm's Avatar
Re: 2jz gte in a no turbo
ok thanks
Old 04-10-2004, 12:33 PM
BobbyisKing BobbyisKing is offline
non turbo supra? what year? mk3 or mk4? it'll fit both, but mk4 will be easier because it will be almost a bolt on motor. mk3, more modifications as i heard it will barely fit the motor but it will fit.
Old 04-10-2004, 02:21 PM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Same chassis... same mounting points... bolt-in. Like I've always said, if you have to ask it's probably to difficult for you. Like Amish kid said, diff trans, diff driveshaft, different electronics/wiring harness, diff block, head, mounts, and the list goes on. You'd be best off getting a TT half-cut and swapping everything over.
Old 04-13-2004, 06:00 PM
JDM3.0SuPrA JDM3.0SuPrA is offline
Send a message via AIM to JDM3.0SuPrA
i say go for it...if my friend can put one in an MkII with the 6 speed tranny then u can put one in a 4th gen...but like project said u may not kno enough to begin the journey..if u got the time and $$..and ur willing to possibly screw up ur car for good then go fer it..question tho..why dont u just buy the twin turbo set up for ur existing engine if its a 4th gen? and if its a third gen. then get the third gen. setup and put a T76 up in there..shit will tear..thats wut im lookin to do with my MkII..so if anyone knows someone who has the stock turbo parts from an MkIII let me kno...
JDM 3.0L SuPrA
Old 04-23-2004, 02:25 PM
flyinMKIV's Avatar
flyinMKIV flyinMKIV is offline
AF - Advisor
Send a message via AIM to flyinMKIV
you'll need a different wiring harness, rear end, ECU, and tranny to do the swap sucessfully. The na tranny will fall from the amount of stock boost on it. the rear end in a TT car has a factory LSD so you'll need that, the ECU and wiring harness for obvious reasons. It can be done, but it's easier just to buy a new car. Trust me.
Alright guys. About to start the 2JZ GTE Swap. IsuzuFire Engineering/ Technical 7 12-30-2009 01:21 PM
2jz-gte vs 2jz-ge. Please i need some help! Alex_me Performance 8 02-14-2007 03:36 PM
2jz-gte turbo upgrade? Tacopower Performance 2 02-14-2005 02:52 PM
Aluminum Block Single turbo 2JZ-GTE MKIISupra General 2 01-30-2004 08:08 PM
2JZ-GTE Motor, Aftermarket turbo pictures? mike@af Car Modeling 8 06-17-2003 11:48 AM
