Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-09-2004, 12:26 PM
GSS123 GSS123 is offline
Changing antifreeze in 1996 Corolla
There doesn't appear to any ideal location to plumb in a coolant system flush kit. All the factory hoses are very short with little room to splice in the flush adaptor. So I was planning on removing the engine coolent by removing the block drain plug near the oil filter. The plug is not moving at all. I suspect that it has never been removed and the alluminum block and steel plug have become like one unit. Anyone out there fought this problem and won?
I may just drain the radiator and reservoir and call it good? But would like to drain as much of the old coolent as possible.
Second question should I use dealer supplied (Toyota recommended) antifreeze or will any good aftermarket type work as well?
131,000 miles and going strong
Changing antifreeze in 4/runner Tony Whelan 4Runner/GX470 3 12-25-2005 09:45 PM
Changing AntiFreeze, Flushing Radiator 1534dover Riviera 4 10-13-2005 07:23 PM
changing antifreeze jeep_cj4x4 Silverado 3 01-04-2005 08:35 AM
97 Cavalier Change Antifreeze pnoel Cavalier 1 10-06-2004 03:01 PM
