Old 04-09-2004, 10:29 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Air Bag Light
When it was around 0 degrees out my air bag light would come on but when it got a little warmer it stayed out. No it's in the 60's and it has started to stay on again. Is there any way I can trouble shoot the system and find the problem. I have an OBD-II scanner, will that help?
Thanks,
Sonny
Old 04-09-2004, 03:40 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Air Bag Light
does the light flash? if it does it's does it's trying to tell you a code. unless you have a very good scanner like a snap-on it won't help you with air bag or abs codes.
Old 04-09-2004, 09:46 PM
Sonny01's Avatar
Re: Air Bag Light
It flashes for a few seconds every time I start up and then stays on.
Old 04-27-2004, 07:15 PM
Imcgyver Imcgyver is offline
air bag light
I have a 1996 Tahoe same problem when cold the light stays on, warms up(outside not motor) it goes out sometimes I need to restart the car sometimes it goes out driving down the road.
Any info would help Thank you
Old 05-23-2004, 09:04 PM
praterguys praterguys is offline
Re: Air Bag Light
my 96 blazer air bag light comes on flashes seven times then stays on anyone got any ideas,thanx
Old 05-24-2004, 07:06 AM
michelq michelq is offline
Re: Air Bag Light
you can work on your car to save money.now try to work on saving your life. leave the air bag alone
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
96 abs & brake light, air bag light all on bobkhi Dakota 1 09-15-2006 10:37 AM
check engine light and air bag light are on! ur_06 Accent | Verna 1 01-05-2005 04:43 PM
