Old 04-08-2004, 08:10 PM
91civicDXdude's Avatar
turbo civic track update with VIDEO & slips... 1/8 mile
so i finally got out to the track last night.. its only an 1/8 mile, but atleast i can judge my improvement.
my best two runs were:
60' - 2.343
1/8- 9.435
MPH-78.67
60' - 2.332
1/8- 9.363
MPH-80.50
http://www.pgmfi.org/~jparker/host/943.mpg <- right click and save as
I was having very bad traction problems because the red neck at the lights wouldn't let me use the water box and i was on slicks, so you know how that went. anyways i had fun and promised time slips, so there you go.
btw, that should translate into a low low 14 or high 13 quarter mile.
Old 04-08-2004, 08:27 PM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Re: turbo civic track update with VIDEO & slips... 1/8 mile
nice
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 04-08-2004, 08:54 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
hell is up with your car it sounds hurting?
quick times and nice vid.
Old 04-08-2004, 08:58 PM
it sounds hurting? thats about what a cammed out SOHC VTEC turbo sounds like with an open dump pipe..
Old 04-08-2004, 09:06 PM
Ace$nyper's Avatar
Banned
oooo well if its probbly the open pipe and cam that gave it that sound. Good thing its not hurting i know you just got that thing all set nicely now and it sure is haulin
Old 04-08-2004, 09:46 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Fun times... What's a water box?
Old 04-08-2004, 09:54 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
holy crap man your civic sounds bad assed!!! the blow off, the rough idle...ahhh my dream SOHC...
Did he just not let you burn out at all or didnt let you burn out in water? Cause those 60 foots look pretty bad for slicks!
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 04-09-2004, 06:36 AM
a water box is a small channel of water that you drive through to make the slicks wet so you can easily do a burnout to heat them up good.
the guy pointed me to the dry lane with no water, so i tried the only thing i could, since slicks need to be very warm to work properly...pull the ebrake and do a burnout which didnt work so well, because slicks get decent traction (even cold) so all i did was burnout for a very short distance and drag the back tires skidding along locked
so yes, i was very disappointed in my 60', but next time i go, i will have actual drag slicks, not road race slicks and i will make the guy let me get in the waterbox.
Old 04-09-2004, 01:06 PM
GTA's Avatar
GTA GTA is offline
Whee..
car sounds like a few cars i've seen around here. nice run though, too bad the didnt let you use the other lane since there was no one in it
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-10-2004, 08:44 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
awesome man, looks and sounds really good! thats making me want my own turbo even more!
Old 04-10-2004, 09:40 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
those times translate into 14.5-14.7's
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-10-2004, 10:03 AM
there is no translation into 1/4 mile. my car really starts to pick up speed the longer i get on it, the 1/8 isnt shit. I *will* run 13s.
last night, i took my maps back to nothing... tuned my vacuum from scratch using hybrid pm7/pm6 maps with tuning. I made another boost controller off the wastegate, i was losing boost from the wastegate not closing properly. i was struggling to hold 8psi and wasnt getting full spool until almost 5,000 rpm! now im hitting 10psi by about 3500 and pulling all the way to rev limit at 7800.
I should be going back to the track this week or next... the times didnt impress me all that much, i was sure i would run a 9.0 or 8.9.
we'll see.
Old 04-10-2004, 10:15 AM
that track sucks dick, go somewhere else
1991 Honda Crx Si
Old 04-10-2004, 10:19 AM
try launching at the desired rpm holding it there, you'll be more consistant like that
you should run way better especially with all that weight reduction....
1991 Honda Crx Si
Old 04-11-2004, 01:31 AM
i have launch control.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
