Old 04-08-2004, 05:18 PM
toe toe is offline
Angry 94 Escort problem
Recently i have purchased a escort 94 model, and have problems turning the key to start the engine. Time to time is does work 1st go, but sometimes i have to give the weel a bit of a turn before the key turns to start the engine, today its totally ceased up and will not turn at all, any sugestions?
Toe
Old 04-09-2004, 09:37 AM
pcv pcv is offline
Replace the key cylinder. You should have done it when it was giving you problems.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 04-10-2004, 08:56 AM
daytrader daytrader is offline
I Have the same problem with my 95 - Take some WD-40 and spray the inside the ignition key hole... Juice it up good.. Make sure you place an old rag/towel below to catch the over flow... Run the key in and out a few time an try to turn it... This should work for a while.. Keep the can of WD-40 with you in case you need it again... Been doing this for over a year now.. Not worth the money they want for replacing the key cylinder. If it were that simple, I would have doen that, but as usual, its a "special" one... Ask any well known locksmith....
Just like the escorts transmittion... Go ask about a quote to rebuilt one of those... about 1500 - 2000 bucks and that if theres no other problems... I was lucky to have it fixed for $1150.00
Cheap car, but very expensive parts and repairs
Old 04-16-2004, 11:34 PM
hate2loveford hate2loveford is offline
It's a stupid question, but..
I had the same problem once and was put to shame by my brother-in-law who turned the stering wheel a little, and pow! I was embaressed as he gentle turned the key to start.
Old 04-17-2004, 06:26 AM
dxrflyboy dxrflyboy is offline
Re: 94 Escort problem
Turning the key off with the wheel cranked to one side is like parking on a hill without the P-brake on. There is a torque load on the locking mechanism, which needs to be relieved before the key can be turned. If it gets forced, it will eventually fail and cause problems. If the key jams, the first thing to do is turn the wheel in the opposite direction from where the lock is holding it and gently turn the key. Hopefully, your lock cylinder/mechanism hasn't been damaged.
Escort 99 keeps jumping on first drive of day for about 150 Yards (CEL 0401) MyEscort99 Escort 4 04-02-2009 11:11 AM
90 escort problem mycaddy Escort 2 05-08-2004 10:20 PM
'97 Escort Problems... yotatechie04 Escort 0 03-19-2004 01:13 PM
'97 Escort Problem Redcap81 Escort 3 02-27-2004 05:19 PM
92 Escort Problems thekrispdj Escort 2 01-30-2004 12:21 AM
