Old 04-07-2004, 11:20 PM
SikNingStang SikNingStang is offline
Send a message via AIM to SikNingStang
Gear Ratio
I read in another thread that there is a metal tag on the rear-end of the Mustang that will tell you the gear ratio. I looked at mine the other day curious to see what ratio I have and I couldn't figure what the ratio was the only thing that stood out as being a ratio was 2 23 but I really don't think I have a 2.23 gear ratio... What am I supposed to look for?
Old 04-07-2004, 11:29 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I'm assuming it was pretty corroded. It probably said 2:73, which was a very common stock gear.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 04-07-2004, 11:37 PM
Re: Gear Ratio
I might have just read it wrong. It wasn't corroded at all, it was in perfect shape just a lil dirty, but I wiped that off... I was also reading it sideways so maybe I did just read it wrong. I'll check tomorrow. Thanks... although I was hoping for 3.08's but oh well
Old 04-08-2004, 08:13 PM
mustangman mustangman is offline
Re: Gear Ratio
Check the sticker in the drivers side door jamb.
M (I think) corresponds to a 2.73
Z corresponds to a 3.08
E corresponds to a 3.27
I swiped this info from another forum, so I can't be sure how accurate it is, and it was for 94-95 stangs. Maybe somebody here can elaborate further on it.
Old 04-08-2004, 08:32 PM
Re: Gear Ratio
Also, unless your the original owner of the car, you don't know if someome switched the gears or not. That being the case your next best bet is to do this:
Jack the rear of the car up, put a mark on the drive shaft and spin the tire one full revolution. While spinning the tire, count how many times that mark goes around. If it goes around slightly more than three times, you have a 3.08 gear. If it goes around two and three-quarter times, you have a 2.73 gear. So forth and so on.
Old 04-09-2004, 11:02 AM
john67 john67 is offline
If you really want to know the exact ratio, take off the rear cover and count the teeth on the both the ring gear (the big one) and the pinion gear. Mark the first tooth so you can keep track of where you're at. Once you have the numbers, figuring the ratio is just a math problem. Divide the number of ring gear teeth by the number of pinion gear teeth. Example: 41 / 10 = 4.1
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 10:10 AM
Counting Gears?/ How to find gear ratio? Link85x Camaro Discussions 8 07-08-2005 06:22 PM
Honda D and B Series Transmission Gear Ratios JD@af General Discussion 0 06-02-2001 09:22 AM
Gear-Ratio SolReaver Engineering/ Technical 19 05-07-2001 03:20 AM
Gear Ratios carmaster Need for Speed Series 0 03-13-2001 02:22 PM
