Old 04-07-2004, 01:36 PM
tazz311311 tazz311311 is offline
Send a message via AIM to tazz311311
Unhappy emergency brake wont stay engaged
ive got an '85 S-10 Blazer and the emergency brake wont stay engaged. it works just fine when i hold down the pedal, but when i let go of the pedal it pops back out. if i hold the pedal down for more than 5 seconds it will stay engaged longer, but still pops out after a couple minutes. does anyone know what this could be?
Old 04-08-2004, 08:41 PM
Philo Philo is offline
The 'ratcheting' mechanism is probably worn out. I don't know if they are expensive, but you should be able to find one in the bone yards. You should be able to get the entire unit, including the brake pedal fairly cheap. You might even be able to test it before you remove it if the rear end and other brake stuff is still in place.
Old 11-13-2004, 01:20 PM
PaulVT PaulVT is offline
Re: emergency brake wont stay engaged
I had this same problem with my 2000 2WD S10. You depress the e-brake pedal and it just springs back. I also thought it was a worn racheting mechanism. Before resorting to a replacement, I doused the assembly with WD-40. Firsat lay down some plastic to catch the drips. I'd wear some safety goggles too. You want to get the fluid up behind the plate that covers the mechanism. Get all areas back there.
Depress the pedal a few times between sprays and keep at it. It worked for me. It's been fine for several months now.
If you do have to replace the pedal assy and you go for a salvaged part, I'd recommend getting one off a truck with an automatic transmission. Odds are it is used much less if at all. This post is probably too late for you, but hopefully it helps someone else.
2001 Grand Am Emergency Brake Stuck on MikeyBoy91 Grand AM 0 08-13-2010 10:53 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Parking Brake Wont stay down Jacleary Problem Diagnosis 1 04-22-2008 03:19 PM
Emergency Brake dash light stays on GuyIKnow Firefly 1 08-29-2006 12:09 PM
**HOT** Parking Brake Wont Engage Derrik Foreal Eighty Eight 2 08-06-2006 07:01 PM
