Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-07-2004, 01:42 PM
yinma yinma is offline
87 Camry, Err code 14, Any idea?
When I started the car, it got started but cranked immediately. If I keep puting gas, it is O.K. Otherwise, it cranks cranks, dead. Error code 14: Lost ignition signal. It runs great at most time. Sometimes, it dead when I stopped at a traffic light. Or It cranks to dead after it sits for a while. Any idea? What' wrong with it? thanks
Old 04-07-2004, 09:42 PM
Joe W Joe W is offline
Re: 87 Camry, Err code 14, Any idea?
This is assuming there is no spark.One of the first things to try would be the ignitor.
Old 09-01-2004, 08:40 PM
Tracy_Luster Tracy_Luster is offline
I had a similar problem on my 88 Toyota. The intermittent stalling was fixed for about two months after cleaning some residual oil from the distributor. When it happened again, I replaced the distributor. It hasn't happened since (about 10K miles).
Old 09-01-2004, 09:42 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
First check to see if your coil is getting 12v vs body ground with the key on.
If the coil is getting 12v, if you can find a procedure, check your ignitor and your ignitor circuit to the ECU. Like Joe said, likely to be your ignitor.
code P1582 any ideas? kurkovn2005 '91 - '96 1 11-29-2009 05:39 PM
1996 Camry having trouble starting - Any ideas? Yelena Camry/Camry Hybrid/Vista 10 09-22-2007 04:36 PM
1988 camry with a code 14 craiger787 Camry/Camry Hybrid/Vista 1 07-19-2007 03:29 AM
My 91 silverado odbI code 43 any ideas kjohn Silverado 0 12-29-2005 04:48 PM
EMERGENCY - NEED TOYOTA EXPERT 94 camry LE No Spark Code 14 igniter replaced camryman1 Camry/Camry Hybrid/Vista 4 01-16-2005 08:47 AM
