| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Chop Top How to?????
does anyone know where i can find a chop top how to? i know ive seen one before i just cant find it, any help would be great!
Later, Mike.
http://smg.photobucket.com/albums/v149/aoshima/?start=0 |
Theres one in one of the Scale Auto Enthusiast Books. I cant remember which one it is. I have it at home and the chop top how to is pretty in depth.
As far as any online, Im stumped.
-Mike AF Director of Media / Photographer ![]() [email protected] | AutomotiveForums.com | Flickr Gallery |
Re: Chop Top How to?????
what kind of chopped top
like a lower top or like a convertable? well heres how to do both a chop top cut the top off saving the roof. then cut the posts lower the roof supports.then you will need to cut the window frame and lower that. glue it on mold it back done. convertable cut the roof off with a dremel or saw saving the window frame. |
Re: Re: Chop Top How to?????
I would suggest that you try to search the completed and inprogreess threads *several* times b/c i have also read one here ( I think ). several times b/c you will get diffrent results every time. I would also try to look in the layitlow.com forums HERE . This kind of mod shows up alot more there. If there isn't already a thread someone can make it a simple process for you i'm sure. |
here is some advice given to me when i asked how to do a chop top. my model was a 1:24 diecast
Ok the dreaded chop top. Now if your new to customizing I would stay away from this till you have a handfull under your belt. The choptop on the S-10 road rat nearly killed me. I though I was going to throw it away at one point. Ok if your still reading I haven't scared you away. The key to the chop top is to mark your cuts with masking tape so they are even all the way around. Make sure the amount you cut out is even all the way around...remember measure twice (or more) and cut once. Well except for the windshield. Only make one cut on the A-pillars (the part that holds the windshield). Don't remove the same amount as the rest of the pillars. Thats where I screwed up. I had to lengthing the a-pillars and lean them WAY back to get it to work. If I wouldn't have cut the pillars short it probably would have fit perfectly. I reattached the roof with a very strong epoxy and bondo. I had to do this process twice before I nailed it down. Expect it to be a pain and maybe it won't be so bad for you. Once the pillars are sectioned lay the top back on and then figure how much you have to take off of the A-pillars and windshield. this won't be easy and I don't have an exact way for you to measure it. If you have any specific questions just PM me or make a new post. Good luck.
Click ME for progress thread ![]() Diecast Gallery Diecast How To Modified Diecast Contest |
Well ...this aint really my specialty,but I will add this... I have heard that in additon to what FlySkyline said if you cut the a pilars,then cut the roof from front to back,and side to side(into 4 pieces). You can enlarge the roof with sheet styrene and not have to lenghten the a pillars. I hope that makes sense.
Here is an How to about a Top Chop on a 1/18 Diecast beetle. It's in french but the images speak for themselves.
To see the other pages click on 'La suite' button. Beetle Top Chop Copyright Guillaume Lefèvre aka Maquettedecox |
If only it were as easy as Supermod04 said.
Each type of roof is unique in its chop. The Rambler wagon I just chopped was a simple chop. All of the pilars were basically straight up and down. They were just angled inwards. So basically when i cut the bottoms of the pillars the width became about 2mm too narrow. To fix this I had to cut the entire roof legnthwise, and add 2 1mm strips of styrene to make the whole top wider. All of the pilars lined back up fine and it was a simple glue and putty job. Most cars are much more difficult, and must be sectioned into 4 pieces or more like someone mentioned above. There is a book "Tex Smith's How to Chop Tops" available for pretty cheap. It's for real cars, but it works for our scale too. Here is a page with a diagram that may help. http://www.amazon.com/gp/reader/1878...=1#reader-page
Matt
just draw lines and plan it out. the cutting is easy, t is the prep that sucks |
How much longer until you start posting progress of the Rambler Wagon. I looked through the April ACME pictures and it looks really sweet and I want to see more!
Re: Re: Re: Chop Top How to?????
Matt
Heres one for a 49 Merc that should give you some ideas.
Contrary to what supermod said chopping is an art. You need to consider the orginal roof line, overall shape, symmetry , and does the chop blend witht ht erest of the cars styling? a good chop should look as if the factory designed it in my opinion http://www.cjhilton.com/models/chop.htm |
To make the glass fit easyer you don't want to change the angles of the pillers. The beas and hardest way is to cut the top into at least four pieces. I gust chopped a Chyrsler 3000. Here's some pix, I hope they help.
Mark ![]() ![]()
I like things that melt. I dis-like things that don't melt.
![]() CarsModeling.com. My Scale Model Cars blog. |
