Old 04-06-2004, 04:00 PM
nest08830 nest08830 is offline
Smile 93 Escort 1.9L
Hi!
Just got a 93 Ford Escort 1.9L with 135000 miles couple of weeks back.
Hand Brake Indicator Light does not want to go away. Any Help is greately appreciated. Except for this minor problem the Car Runs great.
Thanks
nest
Old 04-08-2004, 08:45 PM
lawton_kid's Avatar
lawton_kid lawton_kid is offline
Re: 93 Escort 1.9L
Not sure about the '93, but my '97 brake light is for the hand brake AND a malfunction in the main braking circuit. May just need to go by the book and properly bleed the brakes. Most brake systems have a valve in the master cylinder or brake line junction block that gets out of place from brake malfunction OR inproper bleeding.
Old 04-09-2004, 05:46 AM
butch100 butch100 is offline
The brake lamp will also light if the fluid in the resevoir falls below
a certian level..
Old 04-09-2004, 07:49 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 93 Escort 1.9L
Yep... low fluid will do it... have run in to that once or twice myself.
Old 04-16-2004, 11:37 PM
hate2loveford hate2loveford is offline
rear brakes need ajusting?
135k, might be time to check to see if they still touch the drums, if you have drums in the rear.
Old 04-17-2004, 06:21 AM
dxrflyboy dxrflyboy is offline
Re: 93 Escort 1.9L
Low brake fluid is also a good indicator of worn brake pads. As the pads wear, the fluid is displaced from the reservoir into the caliper cylinders. Now is a good time to check your brake linings.
Old 04-17-2004, 11:59 AM
FreakScort's Avatar
FreakScort FreakScort is offline
Send a message via AIM to FreakScort Send a message via MSN to FreakScort
Re: 93 Escort 1.9L
go ahead and upgrade to the GT calpers in the rear and get rid of those drums... new pads and everything and lines should do nicely too... if your going to do it do it right!
The above post is not ment to educate but rather to piss you off.
Stolzes Mitglied von Straßenrittern, Bringt Projektstraßenwaffe
Do you know what 300 horsepower feels like? Oh wait..you drive a Honda.
www.crank0r.com > Life is good
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
