Old 04-06-2004, 01:39 PM
hawcroft hawcroft is offline
loose steering
I bought my son his 1st car yesterday. 1997 mustang. The steering wheel has alot of play in it.The seller said it is because it's a rear wheel drive.Never had one myself so I don't know.Can anyone advise?
Old 04-07-2004, 07:05 AM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
um......It has nothing to do with the fact that it is "rear-wheel drive". My 98 is a bit loose after 6 years of driving....and it's fine
If it it a safety concern, I would take it to a mustang shop and get some of the Steering parts replaced/tightened.
If the car is a bit lowered, It may need a "Bumpsteerkit" or "Camber casters".
I would have it looked at if iti s a "concern"...
Old 04-17-2004, 08:33 PM
price111 price111 is offline
Re: loose steering
Like the previous poster, steering wheel play has NOTHING to do with rear wheel drive. Some things to consider are bad tie rod ends (too much play). You can see this by putting the front tires up on ramps, watching the tie rod ends while someone lightly turns the steering wheel. You can see any play.
A worn steering rack, which aren't that expensive. I had to replace mine with a NAPA re-built unit for around $100. Autozone is about the same. If you can do mechanical work, it's not that bad a job. You will need larger flare wrenches to disconnect the power steering lines. I replaced the tie rod ends at the same time. You'll need a front end alighment afterwards, though.
LOL
Old 04-17-2004, 09:29 PM
SIKCRX SIKCRX is offline
Re: loose steering
when i first got my mustang, before i even drove it, my dad said the steering was a little loose. i dont know if its b/c hes used to driving FWD cars or what. but i replaced something "forgot what it was (some joint" and it help a bit. i think it was called a rag joint or a rack joint, or something.
2.3L pumpin out 105 stock horses, WHAT NOW BISHES
Old 04-17-2004, 11:30 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
mine has a crapload of play in it. next stop for me is napa and i'm getting a new rag joint to fix it. if that doesn't work then flaming river will get my business. they'll have a quick-ratio power rack for fox-bodies within weeks, or so they told me.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
fixing loose steering column toof2 S-10 2 09-29-2005 09:11 PM
Loose Steering Column 95 Riv joeg2246 Riviera 10 06-15-2005 11:22 PM
Loose Steering wheel/ Steering Slop & Tranny P1870 pkspx01 Blazer 10 11-02-2004 03:30 PM
loose steering hoot49 Cherokee 1 07-07-2004 12:21 PM
loose steering colum 1997 bill2 Aurora 3 12-10-2003 03:17 AM
