Old 04-06-2004, 01:14 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Suspension Interchangeability
I'm going to be buying a set of lower arms, spindle/hubs, and upper arms from a DX hatch so finish replacing the suspension parts on my 91 EX to hopefully figure out the suspension problem. Will all these part fit on with no problem?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 04-07-2004, 02:46 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Suspension Interchangeability
you have a 4d EX, and you are changing the front spindles on it with ones from a DX? you do realize that the front suspension on the EX has bigger brakes than the DX right? and that you will be downgrading.....
it will all bolt on fine, but i wouldnt recommend using the DX knuckles
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-07-2004, 06:02 PM
Jay eS Iye's Avatar
is there any way to use my EX brakes on the DX spindle? mine could be bent, not usre its just one of teh things i haven't changed out, so i was gonna get them.
Old 04-09-2004, 12:44 AM
alexdog69's Avatar
alexdog69 alexdog69 is offline
90-91 EX spindles are quite a valuable commodity
you can not replace the 9.5" DX brakes with the Integra-sized 10.3" EX brakes (otherwise everyone would do it)
you can use DA knuckles but the alignment will be off
really your only proper option is to source another set of 90-91 EX knuckles ...
the JDM SiR knuckles are close but you have to shorten and rethread the tie-rods if im not mistaken.. the DA knuckles are the wrong geometry... the DX/Si knuckles have smaller brakes... the STD/HF knuckles have smaller brakes and the wrong # of splines on the axles...
Taurus Interchangable parts rlhoward59 Taurus | Taurus Wagon 3 11-17-2010 11:19 PM
Can all metro transmission interchange? Are there different Gearings? Idaho_Mechanic1984 Metro 6 10-19-2009 05:14 AM
ZR2 suspension 4x4chevymanS10 Performance 10 08-14-2009 11:45 PM
2001 Interceptor version, suspension problems... ratherbestrummin Crown Victoria 0 07-22-2009 06:20 PM
87-91 Camry Rear Suspension Parts F/S nohablaingles Classifieds 0 07-02-2009 10:22 AM
