Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 08-03-2009, 01:16 PM
4x4chevymanS10 4x4chevymanS10 is offline
Exclamation ZR2 suspension
I want to put a ZR2 suspension on my 2001 S10 4wd. anything special I need to do other than buy the parts?
Old 08-03-2009, 08:47 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: ZR2 suspension
You can not just put on a ZR2 suspension. The ZR2 has a completely different frame thats stronger and includes different mounting locations for the lower control arms, rear leaf springs, etc. There are many differences between the std 4x4 and a ZR2. You can put a body lift, wheel spacers and aftermarket fender flares on your truck to get a similar affect but its just not the same .
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 08-03-2009, 10:17 PM
Re: ZR2 suspension
alright well thanks. now i just sound kind of dumb. what are some good shocks/absorbers/ leaf springs to buy that would lift it up a little and make it ride nice off road?
Old 08-03-2009, 10:28 PM
ZL1power69's Avatar
GM S-Series Mod
Re: ZR2 suspension
Bilsteins are probably the best shocks, ZR2s come with them. Cheapest options to lift your truck would be a 2in body lift, lift shackles and add-a-leafs for the rear springs, and a slight t-bar crank in the front (no more than 1in). That should allow you to clear 32in tires (possibly with some trimming). After that you will start getting into 2in, 5in, and 6in suspension lifts which cost over $1,000.
Low 11 sec sleeper
My Cardomain
Old 08-03-2009, 11:45 PM
Re: ZR2 suspension
So when you say cheapest how cheap are you talkin?
Old 08-04-2009, 08:06 PM
duke350 duke350 is offline
Re: ZR2 suspension
A body lift is usually about $100 or so, can catch em on ebay for $20-$30 sometimes. If you want to make your own, lots of guys choose to use hockey pucks. Just get new bolts 1", 2" or 3" longer then stock, depending on how many hockey pucks you use.
Old 08-04-2009, 10:40 PM
ZL1power69's Avatar
GM S-Series Mod
Re: ZR2 suspension
PA 2in body lift is about $100-150, Knaffle lift shackles like I have (strongest shackles for these trucks) are $70, add-a-leafs are $60, and adjusting the t-bars is free.
Low 11 sec sleeper
My Cardomain
Old 08-05-2009, 12:19 AM
Re: ZR2 suspension
If I did the add a lift deL how much would it raise the truck?
And how hard is a body lift to put on?
Old 08-05-2009, 09:39 PM
b1lk1 b1lk1 is offline
Re: ZR2 suspension
Same frame on standard and ZR2 trucks, but the front suspension mounting points are completely different. There is no way to convert a normal truck to a ZR2 without cutting the front half of the frame off and welding in the ZR2 section. The only difference in the rear is a wider rear end housing and larger leaf spring mounting bradckets.
Any lift for these trucks over 2" is gonna be big bucks and any 2-3" lift is gonna involve cranking the bars. I am planning on using ZR2 bars in my truck with the redesigned upper control arms that will allow a 3" lift with relatively good results. Any more than 2" of lift with the stock IFS front end by cranking hte bars will kill CV axles and ball joints fast. When I cranked mine I instantly wrecked on CV shaft and 2 ball joints inside a week. Sure they were on their way out anyways, but it is a major headache to lift these trucks. Body lifts are the best way to fit big tires for cheap money.
Old 08-13-2009, 01:42 PM
Re: ZR2 suspension
Is a body lift pretty easy to do yourself? any special tools i would need?
Old 08-14-2009, 11:45 PM
ZL1power69's Avatar
GM S-Series Mod
Re: ZR2 suspension
Its not hard just time consuming. The bed lift is the easiest part, you just need a couple people to lift the bed. The cab will be the hardest part. You might need to fab up a relocation bracket for the e-brake cable. The kit should come with the relocation brackets for the bumpers and an extension for your fuel filler neck.
Low 11 sec sleeper
My Cardomain
Tags
chevy , s10 , suspension , zr2
