Old 04-06-2004, 01:07 PM
jrvalle jrvalle is offline
1994 Torque control sensor
Can some one help me with this problem, i checked my 1994 sho and the diagnose tells me that the torque control switch is not responding, what is the torque control switch?
Old 04-06-2004, 01:08 PM
Re: 1994 Torque control sensor
what is a torque control switch?
Old 09-19-2004, 03:53 PM
coolbreeze48 coolbreeze48 is offline
The torque control sensor, also know as the TCC Solenoid is installed in the transmission, usually accessible by dropping the trans pan. In most instances it can be changed without the assistance of a machanic if you have some auto knowledge. Some symptoms of failure are: trans won't shift into overdrive, or will not shift out of overdrive thereby locking the trans in high gear, makes for a very jerky slow down in speed and will also cause your vehicle to cut off once you slow enough. Vehicle will crank right back up but as soon as you put the shifter in Drive it will cut right back off because the vehicle is still in high gear (torque converter is locked). It will be like you are driving a straight shift and trying to start off in high gear, which is basically what you are doing. Can work fine for about the first 45 minutes of driving and then start acting up - mine did.
Vaiable valve timing control sensor or camshaft position sensor? 99 Mazda Roadster MX-5/ Miata 2 12-07-2009 09:36 AM
Speed Sensor spgoethals Taurus | Taurus Wagon 3 04-06-2009 06:35 AM
torque converter clutch control sensor can they cause damage when bad? papason LeSabre 2 08-28-2007 12:54 AM
1994 Climate Control GrandyCuban LeSabre 4 07-22-2005 08:43 AM
