Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-06-2004, 12:43 PM
jesus7845 jesus7845 is offline
power windows
dirver window was not working , i changed the motor and the mechinisam. it worked for 3 days , when the window went up the motor locked . we pulled everything out put all new stuff in. it worked for about 3 more days and did it again.
Old 04-07-2004, 09:57 PM
pcv pcv is offline
Check for power at the motor. Is there power? If power is present, verify ground is present at the motor. If you have both, then you have a bad/defective motor. After you install the new one, verify that once the window is up, the power shuts off. If the power stays on, it will burn the motor.
NOTHING LIKE AN OLD CAR.
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 09:25 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
